Pietenpol-List: Help... do I have a major problem? -Reply
Posted: Fri Feb 05, 1999 11:35 pm
Original Posted By: kyle ray
Subject: Pietenpol-List: Help... do I have a major problem? -ReplyI used birch ply and Aerolite glue. Tested gussets both sanded andunsanded. NO failures in any of the glue joints. I concur with most of theothers, test a couple to destruction and get on with the rest of the plane.Greg Cardinal>>> Richard DeCosta 02/05 7:51 pm >>>I just got my copy of "Aircraft Building Techniques" from the EAA andhave read 3-4 chapters. I am now on rib #25, meaning I have done 24ribs before reading the section of the book on plywood.I am a little concerned now, as I have not "scuffed" or sanded myplywood before gluing to the ribs as the book suggests. I did thewater test as described in the book, whereby one pice of scap plywoodis scuffed and the other is not, then water is placed on both. As thebook predicted the water soaked readily into the scuffed piece butkindof beaded on the un-scuffed one, meaning glue would not soak in aswell either.Is this a major factor in the strength of my ribs? Should I scap the25 ribs I have built? or will they be strong enough without thisscuffing?Concerned,Richard==http://www.wrld.com/w3builderNow you can buy my CD at MP3.com:http://db.mp3.com/Visitor/order.php3?cd ... __________
