Pietenpol-List: plywood questions
Posted: Fri Feb 12, 1999 6:10 pm
I have ordered my fuse materials and have a few quick plywoodquestions for anyone with time to anwser.1. Do the large plywood sides of the fuselage need to be all onepiece, or can 2 sheets be used?2. Is 3-ply or 5-ply plywood better?3. Can the same type of plywood be used for the seat parts as used inthe gussets?Thanks,Richard==
http://www.wrld.com/w3builderNow you can buy my CD at MP3.com:
http://db.mp3.com/Visitor/order.php3?cd ... __________
Pietenpol-List: Re: plywood questions
Posted: Fri Feb 12, 1999 7:47 pm
Original Posted By: "D.J.H."
Richardre: your plywood questions. #1 yes you can use two sheets. I did mine thisway be doing a 12 to 1 splice and positioning the splice on a vertical member.I used a belt sander to do the initial bevel and finished it off by shavingwith cut glass. It's easy to keeep it straight...the straighness of the plieswill show you the way. #2 The ply I used was 1/8 inch-seven ply. I think itwas from a/c Spruce. #3 Sure you can use the same material for seats as youdo for gussets but certainly not the same thickness!Don HicksDonanClara(at)aol.com________________________________________________________________________________
Posted: Fri Feb 12, 1999 8:13 pm
Original Posted By:> Richard DeCosta
I bought 1 sheet of kumme (spelling?)mahogany(marine grade)and it easilydid both sides,as it was over 4x8 in deminsion.I think it was 3 ply. Doug
> plywood questions
> > I have ordered my fuse materials and have a few quick plywood> questions for anyone with time to anwser.> > 1. Do the large plywood sides of the fuselage need to be all one> piece, or can 2 sheets be used?> > 2. Is 3-ply or 5-ply plywood better?> > 3. Can the same type of plywood be used for the seat parts as used in> the gussets?> > Thanks,> Richard> > > > ==>
http://www.wrld.com/w3builder> Now you can buy my CD at MP3.com:>
http://db.mp3.com/Visitor/order.php3?cd_id=968> > > ________________________________________________________________________________
