Pietenpol-List: Seat and Shoulder Belts
Posted: Mon Apr 05, 1999 7:18 pm
Hi Group! Can some of you give advice on your seat and shoulder beltinstallation? I lowered the rear seat bottom about one inch and myshoulders are still four inches above the turtle deck when seated on acushion. I understand a shoulder belt should have a slope of less than 15degrees to avoid vertical compression injuries to the spine in a crash. What advice do you all have for the front and rear cockpits?Thanks,Tom__________________________________________________________________________________________
Pietenpol-List: Re: Seat and Shoulder Belts
Posted: Tue Apr 06, 1999 8:59 am
Original Posted By: "BELLISSIMO, DOMENIC"
Turtle deck on mine was raised to shoulder height.1/8 " cable will be anchored at rear of fuselage androuted above helmut box. I have not yet engineeredthe attachment at the rear of the fuselage.Front seat straps will be anchored to cabane struts.Greg Cardinal>>> Thomas E Bowdler 04/05 6:18 PM >>>Hi Group! Can some of you give advice on your seat and shoulder beltinstallation? I lowered the rear seat bottom about one inch and myshoulders are still four inches above the turtle deck when seated onacushion. I understand a shoulder belt should have a slope of less than15degrees to avoid vertical compression injuries to the spine in acrash. What advice do you all have for the front and rear cockpits?Thanks,Tom__________Get completely free e-mail from Juno athttp://
www.juno.com/getjuno.html______________ ... __________
Posted: Tue Apr 06, 1999 12:11 pm
Original Posted By: Michael Hinchman
Here is a couple of shots of how I attached my shoulder harness. I have astandard height deck. Scroll down a bit when you get there.
http://steve.byu.edu/piet.htmSteve E.-----Original Message-----Greg CardinalSent: Tuesday, April 06, 1999 8:00 AMSubject: Pietenpol-List: Re: Seat and Shoulder BeltsTurtle deck on mine was raised to shoulder height.1/8 " cable will be anchored at rear of fuselage androuted above helmut box. I have not yet engineeredthe attachment at the rear of the fuselage.Front seat straps will be anchored to cabane struts.Greg Cardinal>>> Thomas E Bowdler 04/05 6:18 PM >>>Hi Group! Can some of you give advice on your seat and shoulder beltinstallation? I lowered the rear seat bottom about one inch and myshoulders are still four inches above the turtle deck when seated onacushion. I understand a shoulder belt should have a slope of less than15degrees to avoid vertical compression injuries to the spine in acrash. What advice do you all have for the front and rear cockpits?Thanks,Tom__________Get completely free e-mail from Juno athttp://
