Pietenpol-List: ELT
Posted: Tue May 04, 1999 10:02 am
Original Posted By: Michael Cuy
Re Elt: I mounted my Elt on the front cockpit floor in line with the leftside of the front seat. I mounted the antenna on the fairing between the wing & centersection. Mike B (Piet N687MB) ReElt: I mounted my Elt on the frontcockpitfloor in line with the left side of the front seat. Imounted the antennaon the fairing between the wing centersection.size3> Mike B(PietN687MB)________________________________________________________________________________
>> Safety
Posted: Tue May 04, 1999 10:03 am
Howdy from Big "D"I too have an ACK Model E-01 in my GN-1 Aircamper.It is mounted under my rear seat with remote switchesin the rear cockpit. The antenna is mounted atop the right wing. The external handheld radio antenna is mounted on the left wing.The Model E-01 ELT is automatically activated upon sensing a change of velocity, along it's longitudinalaxis, exceeding 3.5 feet per second. It is designedto be removed from the aircraft and used as a personallocating device when it is necessary to leave the sceneof the accident. Not a bad idea when flying low and slowin rural areas.Mike KingGN-177 MK Dallas, TexasLike Steve's, mine has the >I have the ACK ELT in my Air Camper. Mounted behind the front panel on the>fuse crossmember. I may be wrong, but I think the regs say that you have to>have one if you are flying outside your test area, and you have more than>one seat. The ELT was about $200 and has the remote indicators and switch.>I mounted the antenna ahead of the front windshield. It is about 24" long.>Not very authentic looking but the only place I could find a ground plane.>>Steve Eldredge>IT Services>Brigham Young University>>>> -----Original Message----->> Behalf Of Ian>> Holland>> Sent: Monday, May 03, 1999 10:00 PM>> To: Pietenpol Discussion>> Subject: Safety>>>>>> Just a comment on a sad event yesterday. Out at Kakabeka>> Falls our Ultra>> light instructor and a passenger were found in the wreckage of a Cuby>> II. No telling how long they were on the runway. Pictures>> show a typical>> departure stall effect. Will have to wait for the transport safety>> investigation for cause. Kakabeka falls is about 20 NM from>> Thunder Bay>> Airport with lots of trafic into it.>>>> No mention was made of an ELT, even though TB is a busy commercial>> airport. Again will have to wait for the findings. It started my>> thinking of a very light ELT for the Piet. After almost two and a half>> years of building and interacting with the Piet chat group, I don't>> think I have heard the topic come up.>>>> What works (none of them do all the time), what's affordable, and any>> recommendations?>>>> Sure got my wife worked up, as we both knew the instructor.>>>>>>________________________________________________________________________________
