Pietenpol-List: Corvair cooling
Posted: Tue May 25, 1999 10:57 am
Doug,Thanks for the article. I have read that article at least 20 times trying tounderstand what Jim is talking about. Maybe I'm dense.My vacuum was locked out as Bernie and Jim said. My initial timing was 14Deg. + 12 deg. of centrifical advance (I thought), but this was with theoriginal centrifial springs. Then I changed the springs to weeker ones. andreset the advance to 23 deg. + 12 centrifical = 35 deg. This was the Max.one should set the advance accordig to Jim's Bpan article. And Bang.. ithappened anyway. I was using 100 LL. avgas. Of course I don't really knowwhere the advance ended up at full throttle setting since my timing light(red neon) wasn't bright enough to check. This is when it happened. I couldnever get back up to 2600 RPM after that. Ran rough, with smoke (Steve...Ididn't need any oil injected into my exhaust). I tested the compression andfound I had a problem. Courious thing though my overflow vent which waspreviously giving me a positive pressure in the crank is now like a vacuumcleaner sucking air into the crankcase. Cyl. 2, 4 are now contaminated withoil and have been firing intermitent. Checked the wires and plugs they'reO.K. must just be the oil fouling them. Will pull the head this week. Thequestion is ... is there a hole in the pison or are the valves damaged orboth? Stay tuned for the answer?Domenic________________________________________________________________________________
