Pietenpol-List: $15.00 mag will work
Posted: Wed Jun 23, 1999 11:06 pm
while it is true that the mag is driven from the camshaft, the mag gear hasthe same number of teeth as the crankshaft gear, which results in the magturning crankshaft speed. camshaft speed is one half crankshaft speed. in agear driven camshaft, the camshaft rotates in the opposite direction as thecrankshaft. the camshaft then drives the mag gear, resulting in the magrotating in the same direction as the crankshaft. this will allow the magto be driven directly off the end of the crankshaft with no problems. ihave purchesed some of these magnetos, and plan to using one on my model Aadjusted to rotate in either direction, as well as adjusting the timing.the impulse coupler is easily changed for the opposite direction. thesemags have no gear on the drive, but drive from a slot in the mag gearinside the engine. they are a great magnetos at an unbelievable price.________________________________________________________________________________
