Pietenpol-List: Stapling gussets
Posted: Fri Sep 24, 1999 4:00 pm
Some one wrote: "why staple, when you will just remove them" Thestaples also hold the rib together. allowing you to immediately removeit from the jig, flip it over and gusset the other side. Doing one riba day with weights would have burned me out in no time. Staples allowedme to do a rib in 1 hr. 40 min. Once did 4 ribs in one day. Leon S.Also, I never had a single stick split with staples. Also the bestsingle tool I found for the Piet project was the benchtop disc/beltsander. Cut your wood close with a saw and sand to exact fit in seconds.Upsetting wood grain by sanding, as Terry B. put it is noproblem,because you get no strength in end grain any way. You "paint"end grain with glue to seal it.________________________________________________________________________________
