> piano hinge
> piano hinge
Original Posted By: LaurenMWilliams(at)webtv.net (Lauren Williams)
Subject: Pietenpol-List: Re: piano hinge >Mike, > So that means that , in cross section, the hinge would bestanding likean >"A", with the hinge fastened to the inside of the " aileron spars"? >If this is right, do you have to modify anything to get the gapspacing the >same? And finally, is the pin center at the same point asoriginal? >thanks >walt evans >-----Original Message----- >From: Michael D Cuy To: Pietenpol Discussion > >Date: Wednesday, October 06, 1999 8:27 AM >Subject: piano hinge > >question.somethingtorecall. > >________________________________________________________________________________
