Re: Pietenpol-List: Re: Piet. Plans
Posted: Mon Mar 20, 2000 4:29 pm
Original Posted By: Greggotone(at)aol.com
Good day fellow Piet buildersI am new to the piet listing, could you please be so kind to e-mail me thefax no of Don Pietenpol, as I am in South Africa and the snail mail wouldtake forever to get there and back . I want to purchase a set of plans forthe aircamper, any feelings regarding the metal fusalage vs. the woodfuselage.Thanking you all in advanceNorman Stapelbergstapres(at)mweb.co.za-----Original Message-----
Posted: Mon Mar 20, 2000 5:43 pm
Subject: Pietenpol-List: Re: Piet. PlansRon, No problem! Got 'em from the source of course! Mr. Don Pietenpol, 1604 Meadow Circle, SE, Rochester, MN 55904-5251$137 for the full set including 3-piece wing, corvair engine mod, longer fuse plan, and ford A conversion supplements. Hope this helps! Gregg________________________________________________________________________________
Posted: Mon Mar 20, 2000 8:00 pm
Subject: Pietenpol-List: Re: Piet. Plans>>Ron, No problem! Got 'em from the source of course!>Mr. Don Pietenpol, 1604 Meadow Circle, SE, Rochester, MN 55904-5251>$137 for the full set including 3-piece wing, corvair engine mod, longerfuse>plan, and ford A conversion supplements. Hope this helps! Gregg>>________________________________________________________________________________Date: Wed, 22 Mar 2000 10:18:55 -0800 (PST)
Posted: Wed Mar 22, 2000 6:08 am
Subject: Re: Pietenpol-List: Re: Piet. Plans>> Good day fellow Piet builders>>I am new to the piet listing, could you please be so kind to e-mail me the>fax no of Don Pietenpol, as I am in South Africa and the snail mail would>take forever to get there and back . I want to purchase a set of plans for>the aircamper, any feelings regarding the metal fusalage vs. the wood>fuselage.>>Thanking you all in advance>>Norman Stapelberg>stapres(at)mweb.co.za>>-----Original Message----->From: Greggotone(at)aol.com >To: rbutch(at)inreach.com >Date: Tuesday, March 21, 2000 02:00>Subject: Pietenpol-List: Re: Piet. Plans>>>>>>Ron, No problem! Got 'em from the source of course!>>Mr. Don Pietenpol, 1604 Meadow Circle, SE, Rochester, MN 55904-5251>>$137 for the full set including 3-piece wing, corvair engine mod, longer>fuse>>plan, and ford A conversion supplements. Hope this helps! Gregg>>>>>>________________________________________________________________________________
Posted: Wed Mar 22, 2000 12:22 pm
Original Posted By: "B and V Dearinger"
Norman,Hi, welcome to the wonderful world of low and slow! Don Pietenpol's fax and email information is below. Good Luck!Donald PietenpolHome Fax: (507) 289-1279Email: PietenpolDon(at)Juno.comGary Meadows,Spring, TX.________________________________________________________________________________
Posted: Wed Mar 22, 2000 4:09 pm
Original Posted By: Stapelberg Norman/Shelly
Hi As far as wood or metal construction, use the type that you are mostfamiliar with or that is easiest to purchase in your area.I prefer the woodbut that is because it is pretty and smells good.I know ...That sounds likea personal problem.Take care, Bill-----Original Message-----
> Subject: Pietenpol-List: Re: Piet. Plans> > > Greggotone(at)aol.com> >> >Ron, No problem! Got 'em from the source of course!> >Mr. Don Pietenpol, 1604 Meadow Circle, SE,> Rochester, MN 55904-5251> >$137 for the full set including 3-piece wing,> corvair engine mod, longer> fuse> >plan, and ford A conversion supplements. Hope this> helps! Gregg> >> >> > >> through>>
http://www.matronics.com/archives>
http://www.matronics.com/emaillists>> Matronics!>> > > > ________________________________________________________________________________
