Pietenpol-List: Looking for Craig Aho
Posted: Mon Mar 27, 2000 7:19 pm
Original Posted By: dennis yates
Re: Pietenpol-List: book
Posted: Mon Mar 27, 2000 8:19 pm
Original Posted By: "dennis yates"
Do you have a Knox lumber yard near? I was there a few weeks ago and sawsome great wood in the bins for #1sfp tongue and groove flooring.----- Original Message -----
Posted: Mon Mar 27, 2000 9:18 pm
Original Posted By: Rich
Posted: Mon Mar 27, 2000 9:37 pm
Dennis,The article on the bandsaw is in Sport Aviation, Sept 1973 pages 18-19"Chapter 256 Homebuilt Bandsaw"________________________________________________________________________________Subject: Re: Pietenpol-List: book
Posted: Mon Mar 27, 2000 10:02 pm
Original Posted By: Jeff Griffin
11:02:44 PMLook for some poplar. It might be easier to come by in your area.You'll need pretty much the same quality standard as fir. It worksbetter than fir also. Not as nice as spruce, but pretty good.Mike BellColumbia, SCdennis yates (at)matronics.com on 03/27/2000 08:19:08PMPlease respond to pietenpol-list(at)matronics.com Sent by: owner-pietenpol-list-server(at)matronics.com To: pietenpol list cc: Subject: Pietenpol-List: book Hello has anyone seen a book or plans for a bandsawmade of plywood? I remeber seeing it in a EAA magazinea number of years ago. I noticed there are plans forthe EAA work table so thought someone may have seenthis. Also I am not having any luck finding any clearfir in my area I would travel a couple hundred milesif I had to. I live in west central Ill. about 100miles south of the quad cities.________________________________________________________________________________Date: Tue, 28 Mar 2000 23:47:03 -0500
Pietenpol-List: Spar spacing
Posted: Wed Mar 29, 2000 6:12 am
Original Posted By: Michael King
Subject: Pietenpol-List: Spar spacing>>Hi all!> I'm using the Flying Manual reprint to build a Sky Scout. My problem>lies in the spacing of the rear spar. If the spar is 4.75 inches in>height it will not fit where the plans place it. Should the rear spar be>moved foward .75" or should the spar be placed as shown and made .125">shorter to fit between the capstrips? Maybe I shouldn't be trying to lay>everything out on paper first and just build the thing.>>Thanks in advance,>Jeff>>________________________________________________________________________________Date: Wed, 29 Mar 2000 13:27:06 -0600
Re: Pietenpol-List: Spar spacing
Posted: Wed Mar 29, 2000 7:54 am
Jeff,Think this was discussed a while ago. Seems there is a glitch in thesizing. Some decided to bevel the top of the spar. What I did was to notchthe rib in the back/top of the slot where the spar fits. Moving the spar is probably not a good idea, cause changing one dimensionwill change 20 more down the line. Now that I've finished all major parts,you can see why certain dimensions were like they are, but you don't findout till months or years later when things come together.walt-----------------------------------------------------Click here for Free Video!!
http://www.gohip.com/freevideo/-----Original Message-----
