Pietenpol-List: Control system pulleys
Posted: Tue Apr 25, 2000 4:38 pm
Subject: Pietenpol-List: Control system pulleysI'm about done with the left wing on my Piet (3-pc wing) and ready to install the pulleys that reroute the aileron control cables from parallel to the spar out to the aileron horns. I got ahold of 4 3" phenolic aircraft pulleys, but they appear to be too large to fit inside the wing at the angles needed. I understand that there is a minimum recommended pulley diameter for a given cable size .. I plan on using 3/32 cable... but I can't find anything in any of the Tony Bengelis books I have or any of the other reference materials I have. Anyone have those specs? What size pulleys are commonly used for this?Matt Paxton________________________________________________________________________________
