Pietenpol-List: Built up Plywood Spars
Posted: Wed Jun 28, 2000 9:59 pm
Original Posted By: "Rodger & Betty Childs"
Wayne,Sounds good to me. Only one question, is the plywood to to be used the 45 deg. lay up or the 90 deg. lay up? And would it matter which one is used?Well, two questions anyway.The type spar you describe should be straight forward tomake. We use T-88 for our glue and I would guess it's apersonal preference what type you choose as they are allexpensive to buy. Speaking only of the West and the T-88,that is.Also, not being familiar with the West, does it have a broadusable temperature range? Just thinking of your latitude.RodgerPiet in progress________________________________________________________________________________
