Pietenpol-List: Parts
Subject: Pietenpol-List: PartsPieters,Looking for a float for a A-65 stromberg S3A1 carb. Is there a source for such items anywhere on the net?Corky in La with gasoline running out all ears of his carb________________________________________________________________________________Date: Sat, 14 Jul 2001 17:24:20 -0700
RE: Pietenpol-List: Parts
Corky, Have you tried ebay? There is usually a lot of parts listed on there.I'll put out feelers in NW Ohio for ya,,, some one may have one.CarlPlease visit my website atwww.megsinet.net/skycarl-----Original Message-----
Original Posted By: "Al Latham"
Do any of you know of a source for curtiss drain valve seals. It seems you canbuy the valves, but I can't find replacement seals.ThanksPhil Phillips________________________________________________________________________________
Re: Pietenpol-List: Parts
Original Posted By: "Phil Phillips"
Phil,I always got mine at the local FBO. If they have the O ring assortment traythat most FBO's have they should have the correct size.Al Latham----- Original Message -----
Curtis stopped selling the seals. An O ring is not an acceptablereplacement. Best to pitch the curtis and get a safe-air valve. It is abetter design. I will save the curtis valve caused plane crash story foranother day.Chris Bobka----- Original Message -----
The Curtis valve doesn't use an O-ring. It uses a special D-ring that Curtiswill not sell.----- Original Message -----
Subject: Re: Pietenpol-List: PartsI replaced mine with valves from Eagle Fuel Cells and have been very happy with them. Those old Curtiss valves were a pain because it seemed every time Ichecked the fuel I caused a leak.________________________________________________________________________________
Pietenpol-List: Re: Stuck Value
I am going to be listing 2 model A engine blocks and 1 head for sale on ebay. BeforeI do that I thought I should find out if any of our builders community hasa need or interest. Contact me off line if anyone has a need. These have beensitting around for years and their condition is unknown. ThanksJohnSent from my Verizon Wireless BlackBerry________________________________________________________________________________Subject: Pietenpol-List: Re: Stuck Value
could it be from excess lead deposits? from what I have allways been told-avgashas more lead than the old premium or ethyl had.maybe lead buildup on the stemsor carbon if there is some oil going by the guides? I know when I was usingMarvel in my Piper engine it was on advice from an aircraft mechanic becauseof the lack of lead in cargas.but the avgas should give all the valve protectionyou'd need I'd think.have you looked into the ports to see if it is carbonbuildup?RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Plan to get that blade out of the blank !
Subject: Pietenpol-List: Re: PartsI'm with Dan and Jack. I did buy some of the metal fittings for the wings early on in the project because I was intimidated by the metalwork but as I got into the project, I realized that a big part of building a Piet is learning a lot of new skills. Fortunately, we have this group to bounce thingsoff of, and to actually get hands-on help sometimes. And I share Jack's feeling of loss when the Piet was finished, though I love flying it now that it's done. So I'm looking at building a Wittman Buttercup. I figure it'll be kinda like the Pietenpol project, but without this great group of people.Matt PaxtonNX629ML________________________________________________________________________________Subject: Pietenpol-List: Re: Plan to get that blade out of the blank !
Keri-AnnVi Kapler has built a propeller blade duplicator similar to the one in the video.- It works great if you have an original blade that you can use as a guide to "copy".- I am building a jig for my router that I intend to" copy "- the individual airfoil templates I create to rough out the blade stations for any propeller blade that you design.- This will just rough out the airfoil shape, but will guide my carving and sanding tools to complete shaping the blades.- I still intend to use the templates to check the progress of the "shaping" and finishing.- So far I've experimented with a couple of pieces of 2X4 and it looks pretty good.---I would really like to observe a real prop carver install the brass leading edge to the blades.- Anyone know how that is done?DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... 1#352051le, List Admin.________________________________________________________________________________
Pietenpol-List: Corvair College #21
=0A=0A =0A =0A=0A=0ATo all Pietenpol fans who =0Aare planning to use a corvair engine on their planes, the next corvair college [ =0A#21 ]- will be held at =0A=0A Barnwell =0A Regional=0A Airport , Barnwell, S. C. on November 11, =0A12, 13.=0A =0A- =0AFor those who are not =0Afamiliar with a corvair college, it is a gathering of aviation enthusiasts =0Astarted by William Wynne in May of 2000 for those who want expert information on =0Abuilding a corvair engine. Some come to a college to build and test run their =0Aengines, some come to have their engine parts expertly examined, others come to =0Alook and learn. All go away having learned valuable information and having met =0Anumerous new friends. =0A- =0ABecause the colleges have =0Agotten so popular, William has "twisted several arms" and has gotten- -other experts who have also graciously =0Avolunteered their time to attend and share their expertise. Roy Szarafinski, Dan =0AWeseman, Mark Petuniuas, Emory Luth, Mark Langford, Joe Horton among others, are =0Aexpected to be here this year as well as many past college attendees. =0A =0A- =0AMore information is =0Aavailable at William's web site www.flycorvair.com --Local =0Ainformation about facilities at the airport are at www.barnwellregionalairport.com . =0A- =0AFor any specific info, send =0Aan e-mail to barnwellairport@bellsouth and I'll answer =0Apromptly. =0A- =0AP. F. =0ABeck =0ANX747PFThis email was scanned by VIPRE version 4.0.4194 when it was sent, using definitions version 10453________________________________________________________________________________
Original Posted By: "Barnwell Regional Airport"
Propeller craving-1 & 21. 2. Interesting.--------Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "dwilson"
To all Pietenpol fans who are planning to use a corvair engine on their planes, the next corvair college [ #21 ] will be held at Barnwell Regional Airport, Barnwell, S. C. on November 11, 12, 13.For those who are not familiar with a corvair college, it is a gathering of aviation enthusiasts started by William Wynne in May of 2000 for those who want expert information on building a corvair engine. Some come to a college to build and test run their engines, some come to have their engine parts expertly examined, others come to look and learn. All go away having learned valuable information and having met numerous new friends. Because the colleges have gotten so popular, William has "twisted several arms" and has gotten other experts who have also graciously volunteered their time to attend and share their expertise. Roy Szarafinski, Dan Weseman, Mark Petuniuas, Emory Luth, Mark Langford, Joe Horton among others, are expected to be here this year as well as many past college attendees. More information is available at William's web site www.flycorvair.com Local information about facilities at the airport are at www.barnwellregionalairport.com .For any specific info, send an e-mail to barnwellairport@bellsouth and I'll answer promptly.P. F. BeckNX747PFThis email was scanned by VIPRE version 4.0.4194 when it was sent, using definitions version 10453=00________________________________________________________________________________Subject: Pietenpol-List: Re: Plan to get that blade out of the blank !
Original Posted By: Jeff Wilson
Keri-AnnVi Kapler has built a propeller blade duplicator similar to the one in the video.It works great if you have an original blade that you can use as a guide to"copy". I am building a jig for my router that I intend to" copy " the individualairfoil templates I create to rough out the blade stations for any propellerblade that you design. This will just rough out the airfoil shape, butwill guide my carving and sanding tools to complete shaping the blades. I stillintend to use the templates to check the progress of the "shaping" and finishing.So far I've experimented with a couple of pieces of 2X4 and it lookspretty good. I would really like to observe a real prop carver install the brassleading edge to the blades. Anyone know how that is done?DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Re: Plan to get that blade out of the blank !
Original Posted By: airlion
I've checked into covering the leading edge with brass and the short story is thatit is nearly a lost art.Quite difficult to do and maintain. Then there's balancing.The clear laminate is much easier. Although not as ascetically appealing.If you find a DIY guide, let us all know.Jeff WilsonSt. Louis, MO Sent from my iPhoneOn Sep 12, 2011, at 11:40 AM, "dwilson" wrote:> > Keri-Ann> > Vi Kapler has built a propeller blade duplicator similar to the one in the video.It works great if you have an original blade that you can use as a guideto "copy". I am building a jig for my router that I intend to" copy " the individualairfoil templates I create to rough out the blade stations for any propellerblade that you design. This will just rough out the airfoil shape, butwill guide my carving and sanding tools to complete shaping the blades. Istill intend to use the templates to check the progress of the "shaping" and finishing.So far I've experimented with a couple of pieces of 2X4 and it lookspretty good. I would really like to observe a real prop carver install thebrass leading edge to the blades. Anyone know how that is done?> > > Dan> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 051#352051> > > > > > > > > > ________________________________________________________________________________Date: Mon, 12 Sep 2011 11:21:40 -0700 (PDT)
Re: Pietenpol-List: Corvair College #21
Original Posted By: Barnwell Regional Airport
Mr. Beck, please sign me up for attendance at Corvair college #21. Chuck Campbell, 229 Brooks Landing Drive, Winston-Salem, NC 27106 Just received a Dan Weseman 5th Bearing kit. Hope to have my Corvair ready to run at the college. Chuck NX 10003 ----- Original Message -----
Original Posted By: shad bell
Original Posted By: Charles Campbell
Registration is at https://corvaircollege.wufoo.com/forms/ ... gistration .Cal Hoffman ----- Original Message -----
Chuck,I was not aware that Cal had answered your e-mail, so let me give a little more detailed explanation.The way the registration has been set up for years, is that each person registers throught Ken Pavlou who collects all money through a Paypal account. [ we have no way to collect the money ] and just before the College starts, he will send me the collected money, a list of and an address of each person and their e-mail addresses, along with a name badge for each.There is a page our airport web site [ www.barnwellregionalairport.com ] giving more detailed information.All money collected goes to pay for food, drinks and supplies. All of us here at the airport are volunteers.If you have any specific questions, ask away and I'll answer promptly. I can asure you that your will enjoy the college.Thanks, P. F. Beck ----- Original Message -----
Original Posted By: jorge lizarraga
While watching the videos Keri Ann posted, I ran into this gem. The methods usedby the workers in this video are almost as fascinating as their youth and skills.Enjoy!Part One: http://www.youtube.com/watch?v=l9UbnJlhrHAPart Two: http://www.youtube.com/watch?v=OR3e8waXuWkPart Three: http://www.youtube.com/watch?v=WS-XqOsxBHYBrett PhillipsStrasburg, VANX311GPRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 12 Sep 2011 21:20:31 -0700 (PDT)
Great news Shelley, and Kevin will continue receiving our prayers from Colorado.Rick Holland--------Rick HollandRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Parts
Pietenpol-List: Re: Fat Bottom Girl (FBG) rebuild....?
Hi Jim,I have a slew of extra AN bols, nuts, washers, etc., left over from my build. I will prepare a "grab bag" of misc AN hardware . I am sure that Kevin would be able to use at least some of it. How will it work? Let me know the details.You are a saint!Dan HHi Jim,I have a slew of extra AN bols, nuts, washers, etc., left over from my build. I will prepare a "grab bag" of misc AN hardware . I am sure that Kevin would be able to use at least some of it. How will it work? Let me know the details.You are a saint!Dan H________________________________________________________________________________Subject: Pietenpol-List: Re: Fat Bottom Girl (FBG) rebuild....?
IT Girl wrote:> Are you kidding?? of course we will rebuild... I am going to use it as his rehab!I want to see how fast we can be flying again.... this time... 3 piece wing....> > Man! I get to pick the clothes!> > You guys are the bestShelley:If you can use a work table.16 Feet Long X 36" wide, it is yours. Getting it toyou might be a problem, unless some kind person can transport it.Come-on Brent ( Fed Ex ) trucker. you got space. From Palmyra WI 88C.Pieti Lowell- Mr Ben there done that-guyRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 27 Jul 2012 18:42:23 -0500Subject: RE: Pietenpol-List: Parts
