Pietenpol-List: Re: Prop
Posted: Mon Mar 25, 2002 8:19 pm
Original Posted By: clif
guys:I have a co-worker who's father used to own a Grumman Tiger. He gotalzheimers and had to give up the plane. But they kept the prop as akeepsake and sold the plane. It's a McCauley 1A170 FFA 7563 (I aint gotthe slightest idea what that means) But anyway, I have the prop leaning upagainst the wall in my office. It looks like it's in good shape- metalprop. No major nicks. No cracks or anything that I could see with thenekkid eye.I couldnt confirm one way or the other the story on this prop but I have noreason to think there's any story other than the one I've been told. I toldher I would try to find out how much it's worth. I can then put it on ebayor barnstormers for her.Any ideas?Thanks Bert (who needs a vacation badly)________________________________________________________________________________Date: Mon, 25 Mar 2002 18:41:25 -0800
Re: Pietenpol-List: Re: Prop
Posted: Mon Mar 25, 2002 9:22 pm
Original Posted By: Bert Conoly
There is one particular McCauley prop that you had to take off of theGrumman (or keep doing a 100 hour repetitive AD). Many, many Grumman ownershave these props lying around, I have one. It is probably one of those, notmuch use.----- Original Message -----
Pietenpol-List: RE: Prop
Posted: Tue Aug 16, 2005 7:09 am
Pietenpol-List: RE:
Posted: Tue Aug 16, 2005 7:12 am
Original Posted By: harvey.rule(at)bell.ca
RE: Pietenpol-List: RE: Prop
Posted: Tue Aug 16, 2005 7:16 am
I'm looking for anyone who is using an 80 hp Franklin to see what woodenprop they chose for their operations.So far I havn't had a goodresponse.I have info on an 85 hp using a 72X43 but not sure if this isgood for my app.Thanks.________________________________
Posted: Tue Aug 16, 2005 8:25 am
Original Posted By: "Ed G."
I have a 80 hp Franklin which is now a 75hp because I needed new pistons and couldn't find 7:1 compression replacements. I had to go with 6.3:1 which drops it to 75 hp. It's not in the air yet but I just bought my prop from Tennessee props. They recomended a 72 X 42. Since the engine is similar in displacement to the Continental A65 it makes sence to me that they would be the same..The Franklin puts out 65hp at about the same rpm as the Continental but is 75 or 80 hp at 2500 rpm depending on the compression ratio..Sensenich recomended a 72X43 but their price was out of my budget zone..I decide it would be better to error on the low side than to try to swing too much prop for the engine. The tennessee prop has a fairly wide blade so maybe that's where the difference is between the two recomendations..Like I said I haven't flown it yet but did do my homework..Ed Grentzer>From: harvey.rule(at)bell.ca>Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: RE: Pietenpol-List: RE: Prop>Date: Tue, 16 Aug 2005 08:16:40 -0400>>I'm looking for anyone who is using an 80 hp Franklin to see what wooden>prop they chose for their operations.So far I havn't had a good>response.I have info on an 85 hp using a 72X43 but not sure if this is>good for my app.Thanks.>>>________________________________>>From: owner-pietenpol-list-server(at)matronics.com>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of>Phillips, Jack>Sent: August 16, 2005 8:10 AM>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: RE: Prop>>>Chris,>>>I've got a new Sensenich 72 x 40, which is supposed to be a climb prop>for an A65. I get about 2000 rpm static out of it, and cannot get it to>the redline (2300 RPM) in level flight with full throttle. I also have>a St. Croix which was supposedly made for a Pietenpol and it is a 74 x>36. I haven't tried it yet, but intend to do so shortly. I am not>impressed with my plane's ability to climb on a hot day with a heavy>load.>>>Jack Phillips>>NX899JP>>>-----Original Message----->From: owner-pietenpol-list-server(at)matronics.com>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of chris>cummins>Sent: Tuesday, August 16, 2005 8:02 AM>To: Pietenpol-List Digest Server>Subject:>>>What pitch prop are you running with an A65 ? I am leaning towards a 40>or 42. Not sure which one will give me the RPM I desire.>>Chris Cummins>>________________________________________________________________________________
Posted: Tue Aug 16, 2005 8:36 am
Hi Ben..If you're building your control tube to plans useing 1020 or mild steel all is cool..But if your're useing 4130 there is one welding author who says you shouldn't braze 4130 because it can cause it to split..He recomends welding it instead..I learned this after brazing mine with no problems and I've talked to guys who have flying Piets with brazed 4130..But "THEY" say you shouldn't as it can weaken the metal...Ed Grentzer>From: Ben Charvet >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Torque tube bearings?>Date: Mon, 15 Aug 2005 21:16:31 -0400>>>Hi All,>>I'm in the process of fabricating my control sticks and torque tube. I was >planning to build them to the plans using bearings made of 1 inch tubing >that I have reamed to be a smooth fit on the 7/8 in torque tube. I've >noticed several web sites with pictures where the builder has used >ball-bearings in manufactured bearing carriers for the mount of both the >torque tube and the bellcrank for the elevator. I'd like a few opinions >pro/con of doing it Bernard's way, vs ball bearings, and also an idea where >the ball bearings could be purchased. Thanks in advance for the input.>>Ben Charvet>Mims, Fl>>Wing ribs built, fuselage sides joined>>________________________________________________________________________________Subject: RE: Pietenpol-List: RE: PropDate: Tue, 16 Aug 2005 09:46:42 -0400
Posted: Fri Apr 28, 2017 9:31 pm
>>I'm looking for anyone who is using an 80 hp Franklin to see whatwooden>prop they chose for their operations.So far I havn't had a good>response.I have info on an 85 hp using a 72X43 but not sure if this is>good for my app.Thanks.>>>________________________________>>From: owner-pietenpol-list-server(at)matronics.com>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of>Phillips, Jack>Sent: August 16, 2005 8:10 AM>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: RE: Prop>>>Chris,>>>I've got a new Sensenich 72 x 40, which is supposed to be a climb prop>for an A65. I get about 2000 rpm static out of it, and cannot get itto>the redline (2300 RPM) in level flight with full throttle. I also have>a St. Croix which was supposedly made for a Pietenpol and it is a 74 x>36. I haven't tried it yet, but intend to do so shortly. I am not>impressed with my plane's ability to climb on a hot day with a heavy>load.>>>Jack Phillips>>NX899JP>>>-----Original Message----->From: owner-pietenpol-list-server(at)matronics.com>[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of chris>cummins>Sent: Tuesday, August 16, 2005 8:02 AM>To: Pietenpol-List Digest Server>Subject:>>>What pitch prop are you running with an A65 ? I am leaning towards a 40>or 42. Not sure which one will give me the RPM I desire.>>Chris Cummins>>________________________________________________________________________________Date: Tue, 16 Aug 2005 10:01:49 -0400
