Re: Pietenpol-List: Clarification: Rib measurement
Posted: Sun Apr 08, 2007 3:31 am
Original Posted By:> ** Ryan Michalkiewicz
Subject: Re: Pietenpol-List: Clarification: Rib measurementSorry to answer your question with another question but have you read thearchive threads and BPA newsletter article concerning the Riblett 612airfoil for the Pietenpol? If I was were you are in the building process Iwould order the excellent full size 612 airfoil plans from Roman ($10) orget the coordinates from Bill Rewey for a couple bucks. Just an interestingalternative.RickOn 4/8/07, walt evans wrote:>> When I recieved my plans , I got a full sized rib print. This is the one> that I put on the rib board, and made the ribs to.> My Piet flies great with this wing.> Didn't you guys get this??> And as far as the metal fittings,,,just make them 1/4" longer , to stick> out of the layers of fabric, so you can hook a fitting to it.> Walt Evans> NX140DL> "No one ever learned anything by talking">> ----- Original Message -----
Posted: Sun Apr 08, 2007 3:23 pm
Posted: Sun Apr 08, 2007 6:40 pm
Pietenpol-List: Just a few quick rib questions
Posted: Sun Apr 08, 2007 7:02 pm
Original Posted By: Ryan Michalkiewicz
Re:Re: Pietenpol-List: Clarification: Rib measurement
Posted: Mon Apr 09, 2007 8:59 am
Original Posted By: "Ryan Michalkiewicz"
Subject: Re:Re: Pietenpol-List: Clarification: Rib measurement
Re: Re:Re: Pietenpol-List: Clarification: Rib measurement
Posted: Mon Apr 09, 2007 11:10 am
RyanI don't know about the 612, but I will be bringing along a NACA 4412 rib jig and I have a overlay for the regular Piet rib. The 4412 is used on the Champ and also has been used on the Piet. It, like the 612 has better stall habits and is a bit faster thean the Piet airfoil. I will have cap strips there and if you want, you can build a rib or 2.Dick N.----- Original Message -----
Posted: Mon Apr 09, 2007 12:06 pm
FYI I believe the Kitfox uses the the Riblett 30A- 612 airfoilRoman Bukolt NX20795----- Original Message -----
Posted: Mon Apr 09, 2007 12:24 pm
Where will you be? I will be at SNF Tuesday through Friday and would like to see the 612 and anything else concerning the Pietenpols.Thanks!Max----- Original Message -----
Posted: Mon Apr 09, 2007 8:55 pm
Original Posted By: "Max Hegler"
I will be working in the Wood Workshop. It is up near the main entry. For anyne else who wants to stop by and help out we will be assemblying a Volmer VJ 22 fuselage this year. If anyone wants some fast progress on a Piet project next near, let us know. We can fit in another project for the future. The wood workshop is kind of Pietenpol central at the show.Dick N.----- Original Message -----
>>> ** Pietenpol-List: Clarification: Rib measurement
Posted: Mon Apr 09, 2007 10:54 pm
Original Posted By:>> ** Ryan Michalkiewicz
> Subject: Re: Pietenpol-List: Clarification: Rib measurement>> Sorry to answer your question with another question but have you read the> archive threads and BPA newsletter article concerning the Riblett 612> airfoil for the Pietenpol? If I was were you are in the building process I> would order the excellent full size 612 airfoil plans from Roman ($10) or> get the coordinates from Bill Rewey for a couple bucks. Just an > interesting> alternative.>> Rick>> On 4/8/07, walt evans wrote:>>>> When I recieved my plans , I got a full sized rib print. This is the one>> that I put on the rib board, and made the ribs to.>> My Piet flies great with this wing.>> Didn't you guys get this??>> And as far as the metal fittings,,,just make them 1/4" longer , to stick>> out of the layers of fabric, so you can hook a fitting to it.>> Walt Evans>> NX140DL>> "No one ever learned anything by talking">>>> ----- Original Message -----
Original Posted By:>>> ** Ryan Michalkiewicz
>> Subject: Re: Pietenpol-List: Clarification: Rib measurement>>>> Sorry to answer your question with another question but have you read the>> archive threads and BPA newsletter article concerning the Riblett 612>> airfoil for the Pietenpol? If I was were you are in the building process >> I>> would order the excellent full size 612 airfoil plans from Roman ($10) or>> get the coordinates from Bill Rewey for a couple bucks. Just an >> interesting>> alternative.>>>> Rick>>>> On 4/8/07, walt evans wrote:>>>>>> When I recieved my plans , I got a full sized rib print. This is the >>> one>>> that I put on the rib board, and made the ribs to.>>> My Piet flies great with this wing.>>> Didn't you guys get this??>>> And as far as the metal fittings,,,just make them 1/4" longer , to stick>>> out of the layers of fabric, so you can hook a fitting to it.>>> Walt Evans>>> NX140DL>>> "No one ever learned anything by talking">>>>>> ----- Original Message -----
Original Posted By:> > ** Ryan Michalkiewicz
> Subject: Re: Pietenpol-List: Clarification: Rib measurement>> Sorry to answer your question with another question but have you read the> archive threads and BPA newsletter article concerning the Riblett 612> airfoil for the Pietenpol? If I was were you are in the building process I> would order the excellent full size 612 airfoil plans from Roman ($10) or> get the coordinates from Bill Rewey for a couple bucks. Just an> interesting> alternative.>> Rick>> On 4/8/07, walt evans wrote:> >> > When I recieved my plans , I got a full sized rib print. This is the> one> > that I put on the rib board, and made the ribs to.> > My Piet flies great with this wing.> > Didn't you guys get this??> > And as far as the metal fittings,,,just make them 1/4" longer , to stick> > out of the layers of fabric, so you can hook a fitting to it.> > Walt Evans> > NX140DL> > "No one ever learned anything by talking"> >> > ----- Original Message -----
