Pietenpol-List: moving wing back
Posted: Sun Jun 24, 2007 10:38 am
Subject: Pietenpol-List: moving wing backGene, Unless you just want the diagonal struts to be adjustable,a lot of people just use tubing with the end flattened out with a hole drilled in it to bolt to the cabanes and front mount. You can look at Bill Rewey' s piet it is donethis way. Robert Bush ************************************** See what's free at http://www.aol.com.________________________________________________________________________________Date: Sun, 24 Jun 2007 08:46:43 -0700 (PDT)
Re: Pietenpol-List: Moving wing for W & B(changed to NR airshow)
Posted: Sun Jun 24, 2007 1:06 pm
Thanks Shad, that's what I'll probably do if I can't find the 3/8 X 24 barrels. I'm still looking.Gene ----- Original Message -----
Re: Pietenpol-List: moving wing back
Posted: Sun Jun 24, 2007 1:15 pm
Original Posted By: RBush96589(at)aol.com
Thanks Robert. That is one way I could do it but first I'll try to find the 3/8 X 24 barrel so I can use the same system that is there. To use tubing would change the looks somewhat as streamline tubing was used. As Shad pointed out, I can also use a bushing.How's your project coming? Haven't talked with Walter in quite some time. How is he doing on his new RV kit? Also understand they put a new undercarriage on their Piet. Need to get down there and visit. All it takes is time, something I always seem short of.Gene----- Original Message -----
Posted: Sun Jun 24, 2007 3:23 pm
