From: Chethartley1(at)mchsi.comTo: pietenpol-list(at)matronics.com Re: Pi
Posted: Tue Aug 19, 2008 8:44 pm
Original Posted By: Chethartley1(at)mchsi.comTo: pietenpol-list(at)matronics.comSubject: Re: Pi
ChetI was thinking about an eye bolt through the tail post near the bottom.Also adding blocking where the last brace meets the tail post to help transferloads to the brace and longerons.The hinge would look something like the hinge for the bell crank (but welded).Also adding a travel stop so the bungee would always be under some tension and thetail wheel would not flop down in flight. The normal spring is fully compressed at 190lbs soa 400 lb bungee with a 2 to 1 advantage in the tail wheel arm should be about the same.My old tail wheel with two leaf spring compressed with about 100 lbs.Marc
nesday, November 5, 2008 12:02:56 PM=0A> Re: Pietenpol-List: Re: Pi
Posted: Fri Nov 07, 2008 1:21 am
From: eng(at)canadianrogers.comTo: pietenpol-list(at)matronics.com RE: Pi
Posted: Thu Nov 13, 2008 1:08 am
Original Posted By: eng(at)canadianrogers.comTo: pietenpol-list(at)matronics.comSubject: RE: Pi
Hmm. I've yet to fly my Gregga (this weekend=2C crossed fingers) but it has no trim and the fuel tank is in front of the passenger's cockpit. From speaking to those that have flown it (my dad and 2 previous owners) it really doesn't present any sort of problem.JonJon
ics.com>=0ASent: Wednesday, September 16, 2009 2:12:45 PM=0A RE: Pi
Posted: Wed Sep 16, 2009 2:01 pm
=0ASent: Wednesday, March 5, 2014 9:34 PM=0A Re: Pietenpol-List: Pi
Posted: Thu Mar 06, 2014 10:19 am
Original Posted By: Marc Davis
Marc=2CI like the idea=2C do you have any plans to support the attaching point for the turn buckle?NX920Y flying well in MO with no heat problem anymore.Chet_________________________________________________________________Get thousands of games on your PC=2C your mobile phone=2C and the web with Windows=AE.________________________________________________________________________________
Tom=2CJust curious=2C but why are you asking whether a trim system is necessary AFTER you have designed and built one? Since there is none in the plans=2C you must have felt it to be necessary.In any case=2C from what I have read=2C a trim system really only gets used if you have your fuel tank in the fuselage=2C rather than the wing. As the weight of the fuel (located ahead of the CG) is depleted=2C the CG shifts=2C and having a flight-adjustable elevator trim helps to ease the stick forces required to compensate for the shift in weight. When the fuel is in the wing=2C the weight is centered pretty much on the CG=2C so=2C once the plane is trimmed properly=2C fuel burn does not have a major effect.As with all "added features" on the Pietenpol=2C a trim system comes with a "price" - added weight.I haven't yet heard a Pietenpol builder regret making his plane too light.Bill C. _________________________________________________________________Windows Live Hotmail now works up to 70% faster.http://windowslive.com/Explore/Hotmail? ... __________
autiful Stow Ohio=0A=0A=0A=0A> Pietenpol-List: Re: Used P
Posted: Fri Apr 28, 2017 9:39 pm
Original Posted By: Doug
Pietenpol-List message posted by: "Dan P" =0A> =0A> >From Andrew Pietenpol.=0A> =0A> --------=0A> Dan Plett=0A> N28WH=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.matronics.com/viewtopic.p ... #429778=0A> =0A> =0A> =0A> =0A> Attachments: =0A> =0A> http://forums.matronics.com/files/image_670.jpg=0A& Archive Search & Download, 7-Day Browse, Chat, FAQ,=0A>=========================0A> =0A> =0A> =0A=0A =0A =0A =0A=0A =0A=0A=0A =0A=0A =0A=0A=0A=0A=0A=0Ahttp://www.matronics.com/Navigator?Pietenpol-L ... tion=0A=0A =0A =0Acom/Navigator?Pietenpol-List" target="_blank" rel="nofollow">http://wwwhref="http://forums.matronics.com/"; target="_blank" rel="nofollow">htn" target="_blank" rel="nofollow">http://www.matronics.com/contribution== ... ========== -Matt Dralle===================================0A=0A=0A=0A=0A________________________________________________________________________________
