> > RE: Pietenpol-List: Re: Motorcycle master
> > Dick,> > > > I don't think there is such a thing as a cotter> pin> > master link. But there> > are drilled AN393 clevis pins. You will need to> determine> > the length you> > need, based on the application you have.> > Get some #50 roller chain (this chain has pins that> are on> > 5/8" centers) ,> > and disassemble the chain into little bits. The only> part> > you will want is> > the flat outer links (these are about 0.08"> thick).> > These links have holes> > that are 0.20" diameter. The clevis pins are> > 0.19" diameter, which will> > result in a nice loose (non-binding) fit. Then get> some #10> > flat washers and> > some 1/16" cotter pins, and put them together as> shown> > in the attached> > image.> > > > Bill C.> > > > > http://www.matronics.com/Navigator?Pietenpol-List ________________________________________________________________________________Date: Tue, 9 Sep 2008 22:03:53 -0500
