Pietenpol-List: Re: time to cover airplanes/ wings
I did a search on this and couldn't really find much - maybe didn't do it right.. Anyway=2C I'm going to be working on the CC and figured I better make the fittings first in order to get the holes drilled correctly. Assuming you catch every hole at this point (before the wing is assembled) this will work. What about holes that you have to drill once things are together - very little clearance for a drill / bit in some spaces.Tom B. ________________________________________________________________________________Subject: Pietenpol-List: Re: time to cover airplanes/ wings
Re: Pietenpol-List: time to cover airplanes/ wings
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________________________________________________________________________________Subject: Re: Pietenpol-List: time to cover airplanes/ wings
Pietenpol-List: Re: Vi Kapler's Piets
Original Posted By: "dwilson"
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________________________________________________________________________________Subject: Pietenpol-List: Re: Vi Kapler's Piets
Original Posted By: "mike"
Jack, you are correct. Vi is has a timing problem. He believes the timing gearis off one tooth. He plans to check and repair over the winter. Should beready to fly in the spring.DanRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: time to cover airplanes/ wings
Guys! C'mon! They're airplanes. By definition, like babies, they are allbeautiful, even though some are more beautiful than others.[ snippage]Nope the Tri-Pacer is uglier. OK I'll comprimise, Thery're both FUGLY. [more snippage] > Sorry, but Mike is right about the Tri-Champ.> The Tri-Pacer is gawky, but the Tri-Champ is U G L Y. [still more snippage] > > One more thing the Tri-Champ is NOT the ugliest plane, the Tri-Pacer is.I've got about 200hrs in one and it is still ugly. Often called the flyingmilk stool.> ________________________________________________________________________________
Original Posted By: bike.mike(at)comcast.net
You have a point. Beauty is in the eye of the beholder. However=2C In 200+hrs of holding the yoke of a Tri-Pacer I found no beauty in looking at it=2C but found great beauty in the fact that it got me off the ground. And the bomb proof nose gear saved my a** at least once.Doug DeverIn beautiful Stow Ohio
Original Posted By: Wayne Bressler
Guys! C'mon! They're airplanes. By definition=2C like babies=2C they are all beautiful=2C even though some are more beautiful than others.[ snippage]Nope the Tri-Pacer is uglier. OK I'll comprimise=2C Thery're both FUGLY. [more snippage] > Sorry=2C but Mike is right about the Tri-Champ.> The Tri-Pacer is gawky=2C but the Tri-Champ is U G L Y. [still more snippage] > > One more thing the Tri-Champ is NOT the ugliest plane=2C the Tri-Pacer is. I've got about 200hrs in one and it is still ugly. Often called the flying milk stool.> _________________________________________________________________Hotmail: Trusted email with Microsoft=92s powerful SPAM protection.________________________________________________________________________________
