Pietenpol-List: what is a "flight manual" and an "equipment list"
Posted: Tue Jan 26, 2010 12:54 pm
Original Posted By: Dan Yocum
Re: Pietenpol-List: what is a "flight manual" and an "equipment list"
Posted: Tue Jan 26, 2010 2:04 pm
RE: Pietenpol-List: what is a "flight manual" and an "equipment list"
Posted: Tue Jan 26, 2010 8:30 pm
Douwe,Have available a scrapbook of photos showing the build in progress. Inparticular, show every pic you can of you actually working on the plane.Not only does it help qualify you for your "Repairman's Certificate", butthe inspector is likely to get engrossed at looking at the pictures and notask many questions (at least that's what happened with mine).I had a W&B spreadsheet which I showed to the inspector. He never asked fora flight manual (not necessary if you have placards and various "V" speedsmarked on your airspeed indicator). I made up a compass correction card,then swung the compass later.I don't believe a minimum equipment list is necessary unless you will beusing the plane in commercial operation, which as a homebuilt, you can't do.As I mentioned to Dan Helsper, have in mind what you want for a test areaand ask for it - otherwise you will be stuck with whatever the inspectorthinks is appropriate. As long as you justify what you're asking for,you'll probably get it.Jack PhillipsNX899JPRaleigh, NC-----Original Message-----
Re: Pietenpol-List: motorcycle links
Posted: Tue Jan 26, 2010 9:18 pm
Original Posted By: airlion
Thanks DavidIf you mean just hanging out there then no.I haven't made the support bearing yet.Clif>> Nice tank work!>> But that valve control rod - that's not the way you're going to leave it, > is> it?>> David Paule________________________________________________________________________________Date: Wed, 27 Jan 2010 05:37:08 -0800 (PST)
Pietenpol-List: Re: what is a "flight manual" and an "equipment list"
Posted: Thu Jan 28, 2010 1:52 am
Original Posted By: "Xhalin1212"
For all you wing builders, I am planing on building my wings (3-piece) completely then take the fittings off to varnish the wood. Is this ok or is this going to screw something up?ChrisSacramento, CAWestCoastPiet.com________________________________________________________________________________Subject: Pietenpol-List: Re: what is a "flight manual" and an "equipment list"
Posted: Thu Jan 28, 2010 6:14 am
If you chose to do a MEL, be aware that if anything you put on the list does notwork, you cannot legally fly the aircraft. I would not put anything otherthan Altimeter, Airspeed, Tachometer, oil pressure gauge on it. As stated above,you do not need one for your aircraft. Sometimes, Inspectors will ask forone just to see what you say or do.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Posted: Fri May 24, 2013 9:01 pm
Original Posted By: "Fun2av8"
Hey guys I'm looking for a Continental 65 or 85 engine.... I know everybody's looking for them so I'm just throwing it out there. Doesn't have to be low time (higher cost). If you have one sitting in the corner of your hangar let me know.....Contact me on my private email....Charles Burkholder________________________________________________________________________________Subject: Pietenpol-List: Re: what is a "flight manual" and an "equipment list"
