Jon - I agree with you that the band saw is the only way to go to re-saw. FortunatelyI have a Delta band saw that will do just the trick. Thanks for the linkto Highland Hardware. I used to love visiting that store in person when Ilived in Atlanta.Having said that, I don't think my original plan to get 3 slices of cap strip outof a 1" board is going to work. The spruce will be quartersawn, correct? If that is the case, then I will need to cut the 1/2" side of the cap strip outof the thickness of the board to get the grain to run in the right direction.If I can find 5/4 lumber, I could get 2 cap strips out of the thickness ofthe board. The more I think about it, the more I think that I may just get the cap strip fromAircraft Spruce, and get the remaining lumber from McCormick.Someone please set me straight if I am not thinking about this correctly.GaryRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Piet 4 Sale
