Pietenpol-List: Re: Paint discussion ad nauseum
Posted: Fri Feb 04, 2011 10:58 pm
Hi Brad - There are a bunch of us in TX. Curtis Merdan is near you. I'm surehe'll check in. I'm in Austin. You're welcome to come take a look. I'm outof town but will be back mid-March. You can also visit Tim Willis' project inAustin.Kevin--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Paint discussion ad nauseum
Posted: Fri Feb 04, 2011 11:07 pm
BTW: MEK is only the cleaning solvent. I'm pretty darn sure that none of the poly-fiberpoly-tone products use MEK in the coatings.--------Kevin "Axel" PurteeNX899KPAustin/Georgetown, TXRead this topic online here:
Posted: Fri Feb 04, 2011 11:36 pm
Original Posted By:> kevin.purtee(at)us.army.mil
not the finish=2C but the cement is MEK based!! That is why I am using Stewart Systems cement to cover=2C even though I am using dope for the finish. Stewart even blessed me doing that=2C said dope wont hurt the glue. And I thought they would say I had to use their finishes . . . Gene Rambo> Subject: Pietenpol-List: Re: Paint discussion ad nauseum
Pietenpol-List: Piet Directory
Posted: Sat Feb 05, 2011 6:28 am
Hello all, I just sent the listing to all that have submitted their info.If you didn't receive the listing and want to be included fill out thetemplate and return to my home email jack(at)textors.com. Thanks,JackJack Textor29 SW 58th DriveDes Moines, IA 50312www.textors.com________________________________________________________________________________Date: Sat, 5 Feb 2011 08:51:21 -0600 (GMT-06:00)
Re: Pietenpol-List: Re: Paint discussion ad nauseum
Posted: Sat Feb 05, 2011 6:28 pm
Is the Stewert System glue particular about the varnish that is used under it? My son-in-law owns the Benjamin Moore paint store in town and recommended a fancy water based varnish that has very high UV protection and is super easy to use, glossy and totally waterproof...but very expensive. Started using it on the interior of the fuselage where I will not be able to get to later on.Ray KrauseSky Scout ----- Original Message -----
Is the Stewert System glue particular about the varnish that is used under it? My son-in-law owns the Benjamin Moore paint store in town and recommended a fancy water based varnish that has very high UV protection and is super easy to use, glossy and totally waterproof...but very expensive. Started using it on the interior of the fuselage where I will not be able to get to later on. Ray Krause Sky Scout ----- Original Message -----
RE: Pietenpol-List: Re: Paint discussion ad nauseum
Posted: Sun Feb 06, 2011 10:27 am
Original Posted By: raykrause(at)frontiernet.net
No=2C the Stewart glue won't touch anything at all. I used Helmsman semi-gloss poly varnish throughout=2C and the Stewart does not do anything to it=2C nor does nitrate thinner. I think only MEK (and therefore MEK-based Super Seam cement) will llift this stuff. I bought a quart of the expensive two-part epoxy varnish from AS&S that I am not going to use. Never opened. Anyone want to buy it off of me at a discount to get some of my money back??Gene
Posted: Sun Feb 06, 2011 2:08 pm
Gene,Thanks for the response on the nails and the varnish. The loosening of nails in the leading edge makes sense. But if the leading edge is glued and nailed, it seems that the movement would be pretty minimal...guess not. Back to varnishing!Thanks again,Ray Krause ----- Original Message -----
Original Posted By: "Jack"
> To: pietenpol-list(at)matronics.com> .mil>> > BTW: MEK is only the cleaning solvent. I'm pretty darn sure that none of the poly-fiber poly-tone products use MEK in the coatings.> > --------> Kevin "=3BAxel"=3B Purtee> NX899KP> Austin/Georgetown=2C TX> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 688#329688> > > > > > > ============================================> > > ________________________________________________________________________________
Is the Stewert System glue particular about the varnish that is used under it? My son-in-law owns the Benjamin Moore paint store in town and recommended a fancy water based varnish that has very high UV protection and is super easy to use=2C glossy and totally waterproof...but very expensive. Started using it on the interior of the fuselage where I will not be able to get to later on.Ray KrauseSky Scout----- Original Message -----
Original Posted By: airlion
http://forums.matronics.com/viewtopic.p ... 688#329688> > > > > =====================>===================> > > href="
http://www.matronics.com/Navigator?Piet ... nics.com/c ________________________________________________________________________________Date: Sun, 6 Feb 2011 08:32:09 -0800 (PST)
> To: pietenpol-list(at)matronics.com > > > BTW: MEK is only the cleaning solvent. I'm pretty darn sure that none of the poly-fiber poly-tone products use MEK in the coatings. > > -------- > Kevin "Axel" Purtee > NX899KP > Austin/Georgetown, TX > > > > > Read this topic online here: > >
http://forums.matronics.com/viewtopic.p ... 688#329688 > > > > > ===================== >=================== > > > href="
http://www.matronics.com/Navigator?Piet ... cs.com/cst" target=_blank>
http://www.matronics.com/Navigator?Piet ... ______Date: Sun, 6 Feb 2011 12:53:33 -0800 (PST)
