Pietenpol-List: NA-S3 B Stromber Carburetor
Posted: Tue Apr 12, 2011 9:31 am
Original Posted By: "vagabondpa15"
Last night I began making my cabane fittings for the center section. After readinghow to bend the u-shaped material and the minimum radius needed, I proceededto make a fitting. With this u-shaped piece fitting over the spar, I havea good gap in the wood to metal area because of the radiused metal and sharpededged wood. Do most of you sand the wood in that area to fit the radius ofthe metal?--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: NA-S3 B Stromber Carburetor
