Pietenpol-List: spraying latex
Posted: Thu Apr 21, 2011 12:01 pm
Original Posted By: "Jack"
Anyone thinking of doing a latex paint job.My new paint scheme is going to be a "faux clear-doped linen look" with atrim color edging and nose. The ceconite will be sprayed with a tintedclear dope, but the trim color (a weird british green) is proving very hardto match in dope, so I started looking at latex.I just purchased a new hvlp gun for work and just finished some sprayexperiments with latex and I gotta tell you, anybody out there preparing todo a latex paint job should really consider spraying. I simply am amazed athow nice the test panels came out. The semi gloss I used really mimicsdope, or one could easily spray a clear coat of dope on top and it would bedifficult to tell the difference. Now I just take my paint chip to Home Depot, have them put it under thespectrometer, then hit the auto paint shop for the matching enamel for thesheet metal and we're good to go!Secret seems to be diluting with windshield washer fluid for good sprayingqualities (smaller atomization) and floetrol for better flowing qualitiesonce the paint is on the surface. Mixed solution I used took about 25seconds to exit a standard viscosity cup. Seemed almost impossible to get arun on a vertical surface too, which was kinda neat.Douwe________________________________________________________________________________
Original Posted By: "Dortch, Steven D MAJ NG NG FORSCOM"
ReplyTo: pietenpol-list(at)matronics.comSubject: Pietenpol-List: spraying latexAnyone thinking of doing a latex paint = job=85My new paint scheme is going to be a =93faux = clear-doped linen look=94 with atrim color edging and nose. The ceconite = will be sprayed with a tintedclear dope, but the trim color (a weird british = green) is proving veryhard to match in dope, so I started looking at = latex.I just purchased a new hvlp gun for work and just = finished some sprayexperiments with latex and I gotta tell you, anybody out = there preparingto do a latex paint job should really consider spraying. = I simply amamazed at how nice the test panels came out. The semi gloss I used = reallymimics dope, or one could easily spray a clear coat of dope on top and = itwould be difficult to tell the difference. Now I just take my paint chip to Home Depot, have = them put it under thespectrometer, then hit the auto paint shop for the matching = enamel for thesheet metal and we=92re good to = go!Secret seems to be diluting with windshield washer = fluid for good sprayingqualities (smaller atomization) and floetrol for better = flowing qualitiesonce the paint is on the surface. Mixed solution I used = took about 25seconds to exit a standard viscosity cup. Seemed almost = impossible to geta run on a vertical surface too, which was kinda = neat.Douwe3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref='3D"http://www.matronics.com/Navigator?Piet ... =3D=3D~=B2 _____ ________________________________________________________________________________
Re: Pietenpol-List: spraying latex
Posted: Thu Apr 21, 2011 12:11 pm
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________________________________________________________________________________Date: Thu, 21 Apr 2011 13:16:57 -0400
Pietenpol-List: Re: Now I'm a Model A guy too
Posted: Thu Apr 21, 2011 2:05 pm
Or you can tune a chain saw but you cant tune a banjo________________________________________________________________________________Subject: Pietenpol-List: Re: Now I'm a Model A guy too
Posted: Thu Apr 21, 2011 2:57 pm
Original Posted By: Scott Knowlton
Ben you have it all man. The two go together perfectly. Congrats!--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Cuttin' metal
Posted: Thu Apr 21, 2011 4:30 pm
Original Posted By:> cdawson5854(at)shaw.ca
I love the spark flying grinder part. What a great shop safety video. "Kids=2C don't try this at home".Scott Knowlton
RE: Pietenpol-List: Re: Cuttin' metal
Posted: Thu Apr 21, 2011 4:42 pm
What have y'all got against banjos? I don't get near as many complaintswhen I play my banjo as I do when I play my bagpipe.Jack PhillipsNX899JP "Icarus Plummet"Smith Mountain Lake, Virginia _____
Posted: Fri Apr 22, 2011 7:47 am
Subject: Re: Pietenpol-List: Airframe for saleWhere is it located? Hangared or stored outside? In a message dated 4/22/2011 8:44:28 A.M. Eastern Daylight Time, wyliejohnson45(at)gmail.com writes:--> Pietenpol-List message posted by: "olflyr45" Pietenpol completed in 2002. Has flown about 200 hrs. For sale less firewall forward. $5,000. Pictures available.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 22 Apr 2011 07:28:39 -0600Subject: Re: Pietenpol-List: spraying latex
RE: Pietenpol-List: spraying latex
Posted: Fri Apr 22, 2011 11:41 pm
I thought the reason for brushing was to work the water base paint into thefabric so it will mechanically attach its self to the fabric. I seem torecall the chemical based paints chemically bond to the fabric. True False?ChrisSacramento, CaWestcoastpiet.com _____
Posted: Sat Apr 23, 2011 9:47 am
My intent is to brush a primer coat, then spray=85.but I do like that brushedlook on The Bell Pietenpol!Gary
> Re: Pietenpol-List: Cuttin' metal
> > > How to cut up all that iron y'all bin buyin recently.> Check out the grinder too. I had one like it for> years.> > http://www.youtube.com/watch?v=qDBrud9R ... ure=relmfu> > Clif> > Keep them lemons comin' ! :-)> ============================================> > > ________________________________________________________________________________
