Pietenpol-List: And so it begins.... In earnest
Douwe, I use those trash bags that are really big. I just slip it over the engine andtie a wire around it at the rear of the engine. I don't remember where I got thembut they work great.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531Started building NX510JD July, 2009wing, tailfeathers done, fuselage rollingusing Lycoming O-235Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Fri, 20 May 2011 21:24:35 -0700Subject: Pietenpol-List: And so it begins.... In earnest
Re: Pietenpol-List: West Coast Piet Gathering
Subject: Re: Pietenpol-List: West Coast Piet Gathering
RE: Pietenpol-List: And so it begins.... In earnest
Mark,That is indeed great news! I admire you for holding on to The Dream! Andyour work area is to be envied=85For 8 years I have had a planer, partially dismantled, stuffed away in mygarage. I dug it out a few weeks ago, spent an hour putting it backtogether, and used it to plane down the =BD=94 spars for the aileron bays. =91tillnow, everything had been done just with a table saw, and the results havebeen OK, but, if I had it to do over, I would do as you are, and use theplaner more extensively.See you at Frazier Lake!Gary
Re: RE: Pietenpol-List: And so it begins.... In earnest
Subject: Re: RE: Pietenpol-List: And so it begins.... In earnest
Re: Pietenpol-List: Re: Plywood Order
> Location: Frazier Lake (very nice grass strip airport just north of HollisterCA)>> If you're planning on coming it would be nice if you could rsvp to Charlie Miller(our host)> or my self Mike Groah so Charlie can plan the food. We had a great turn outand fun time> last year> and I'm sure this year will be even better.>> Attached is the info sheet for the event which has the times, phone numbers andother details.>> Thanks, and I hope to see you in June!>> Mike Groah> Tulare CA> *>> *>>________________________________________________________________________________Date: Fri, 20 May 2011 21:39:20 -0700Subject: Re: Pietenpol-List: Re: Plywood Order
