Pietenpol-List: Contact info for Ken Perkins
Posted: Sat Aug 13, 2011 12:52 pm
Original Posted By: Don Rucker
Mike:I noted in this list, that you had a prop disassemble in flight, and kept the enginerunning for your added power to get you where you finally set down.Is that a bean on the prop ?How soon did you flip the Mags off ?Did only one blade separate ? Other than hitting a couple beans, and failing theother blade And to think you had just circumcised Lake Michigan 360 degrees in the T craft.A good survival landing Mike, you and passenger survived without a scratch,Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sat, 13 Aug 2011 22:25:53 -0500Subject: Pietenpol-List: Contact info for Ken Perkins
