Pietenpol-List: Mystery engine
Original Posted By: "MyrickPiet"
Guess the "right" airfoil depends on what you want... Sent from my iPhoneOn Sep 24, 2011, at 10:42 PM, "dwilson" wrote:> > I was told by a very good friend of Bernie's that He had actually tried an airfoilwith no undercamber. He tried the clark Y airfoil and was not pleasedwith the performance. He thought that he could design an airfoil that wouldperform better. He experimented with a number of airfoils. He designed the airfoiland concluded that it performed better than the Clark Y that was used onsimilar " ships ".> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 145#353145> > > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Mystery engine
This has befuddeled me for several years. I thought I knew engines. I'm givingthe Piet list first chance to come up with an answer for me. Does anyone knowanything about the attached engine? Watercooled, 5 cyl radial, dual plugs,Bosch injected, Garrett turbocharged, prop reduction belts. I suspect it isa one-of but that's a LOT of work and expense. Any gearheads out there have someideas?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/myst ... ______Date: Sun, 25 Sep 2011 09:08:11 -0400 (GMT-04:00)
Pietenpol-List: Re: Mystery engine
MyrickPiet wrote:> This has befuddeled me for several years. I thought I knew engines. I'm givingthe Piet list first chance to come up with an answer for me. Does anyoneknow anything about the attached engine? Watercooled, 5 cyl radial, dual plugs,Bosch injected, Garrett turbocharged, prop reduction belts. I suspect it isa one-of but that's a LOT of work and expense. Any gearheads out there havesome ideas?It's not a Wankel because it has 5 injectors, Wankels only have one injector/ firingper rev for each rotor and this has one bank of radial cylinders.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mystery engine
Actually, I think that the radial engine is on a stand next to this engine, becauseyou don't see the cylinders in subsequent pictures. I think that it is a single rotor rotary engine, but I am by no means an engineexpert. I am going to post the photos on a rotary engine forum and see what theycome up with.--------Semper Fi,Terry HandRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mystery engine
Original Posted By: Jim Boyer
Notice how the turbo sends induction air into a rear plenum? This would seem toindicate some sort of sleeve port for each cylinder to receive its charge. Also it seems to be set up as a pusher engine because the turbo is fed from therear of the firewall and exhaust is facing the prop disc. I know this is notPiet related but I owned a Piet for years and have followed this site for 11years. You guys all seem like old pals who like a mental challenge.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Sun, 25 Sep 2011 20:53:25 +0000 (UTC)
