Pietenpol-List: Congratulations Jeff!
Posted: Wed Nov 30, 2011 7:48 am
Congrats Jeff!Truly a big day. Running one's engine for the first time is a bigmotivational boost, especially when it's mounted on the fuse. Great plane!!Douwe________________________________________________________________________________
Pietenpol-List: Re: Congratulations Jeff!
Posted: Wed Nov 30, 2011 8:44 am
Original Posted By: "bender"
Thanks guys..I guess i got lucky Dan... reserved it last year..i played in the faa site fora long time to find the number that fitMy tach was new old stock..dated 1931 and i was told it was from a tiger moth...igot it and the airspeed from the same guy... maybe the Moth had another gearto slow it down.. i was just going to hook up an electric tach till i got aspeed reducer for the mechanical one and see where i was running.i dig the sound... my buddy here at work expected it to be louderthe ignition is a dual point with the coil switcher like the corvair guys use..all grins herejeffRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Congratulations Jeff!
Posted: Wed Nov 30, 2011 9:42 am
brian.e.jardine@l-3com.com
Thanks Douwe...i really should come and see you someday.. you're so closejeffRead this topic online here:
Pietenpol-List: Re: Hi I'm new here.
Posted: Wed Nov 30, 2011 9:48 am
Group,Saw this ad in our local online classifieds. O-235-C for sale $1500. Iknow nothing about it or have any affiliation...Just passing it on.
http://www.ksl.com/index.php?nid=218&ad ... ___Subject: Pietenpol-List: Re: Hi I'm new here.
Posted: Wed Nov 30, 2011 10:39 am
Welcome to the group, Matthijs.Since nobody else has mentioned it yet, I'll caution against making the metal fittingsbefore the wooden structure is built.Many builders have thought the same idea before, but, because each Air Camper ishand-built by different individuals, each Air Camper will be slightly different,and therefore, the metal fittings will also need to be made to fit that actualplane which they will be used on. The differences will be small, but probablybig enough to make many pre-fabricated parts useless. The fittings MIGHTfit if built as-drawn, but it is highly likely that many will not.Bill C.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 30 Nov 2011 11:05:18 -0600
