Pietenpol-List: plywood wrap-around leading edge idea
Subject: Pietenpol-List: plywood wrap-around leading edge idea I've had the pleasure of periodically seeing Mike Perez's progress on his Pietenpol and was very impressed with the design idea and the fit and finish of Mike's all-plywood leading edge wrap-aroundtechnique. (the method that Chuck Campbell recently copied) It sure is refreshing to see what innovations builders come up with because just when you think you've seen it all, you probably haven't. EAA's French Valley, CA Chapter 1279's Pietenpol is like that and has some very clever, simple, and elegant modifications that simplicate and add lightness!http://www.eaa1279.org/pietenpol_project.htmlMike C.________________________________________________________________________________Date: Tue, 31 Jan 2012 14:56:25 -0800 (PST)
