Pietenpol-List: Radiator pressure
Posted: Mon Feb 27, 2012 10:37 am
Do you model A guys use a pressure radiator cap ??i know the cars didn'ti had an old 16lb cap laying around and put it on the piet to run it and i'm gettingquite a bit of pressure i guess... its blowing over some water at high rpm..I'm concerned that there could be a head gasket problem.. the oil is ok.. don'tsee anything in the cylinders.. its not hot but its pushing a little water out..just ran it again for a while.. never saw more than 165 degand its holding pressure still in the hangar..jeffRead this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Mon, 27 Feb 2012 08:47:20 -0800 (PST)
Re: Pietenpol-List: Radiator pressure
Posted: Mon Feb 27, 2012 11:26 am
Original Posted By: "bender"
I don't use a pressurized cap, same as the cars, and I don't recall seeing anyone use one. Larry----- Original Message -----
Posted: Mon Feb 27, 2012 12:29 pm
Original Posted By: bender
Jeff,I have an overflow, outlet in the neck of the radiator. So far I always get some blowing over of some water at full power. I think it is a function of the water pump throwing the water up there. I restricted the fitting down real small and that helped. I need to also create some kind of labyrinth to lesson the amount. Dan HelsperPuryear, TN-----Original Message-----
