Original Posted By: Jim Boyer
Getting closer to drilling the lower gear lugs to set the angle of thewheels at 2 degrees. I plan to use a digital angle gauge but wanted adouble check. I plan to install a wedge shim on top of the axle and thentop it with a piece of angle the full length across the top of both axlesside to side. 2 percent would be the angle. To determine the height of thewedge, what figure would I use for the base? The distance to the fuselageside?Thanks!Jack TextorDSMNX1929T________________________________________________________________________________Date: Mon, 7 May 2012 18:51:46 +0000 (UTC)
