Jim,Please stop referring to the "Mystery line" on your plans. There is no mystery.It's called a firewall.I believe your plane has the "long" fuselage. The photo clips that you postedare from the drawings for the "standard" fuselage (from the 1933 Improved AirCamper plans). The basic dimensions for the long fuselage were provided on a supplementaryplan sheet, drawn up in the 1960's. However, there isn't a versionof the drawing in your photo that applies to the long fuselage, so it's VERYlikely that the builder of your plane just wrote in pencil, the dimensions thatapplied to his (your) plane. The distance from the firewall to the wing leadingedge very well may be different from the number on your plans, as thewing may have been shifted to get the CG to fall in the acceptable range.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Archive searches
