Pietenpol-List: Combustible lines
Original Posted By: "giacummo"
Thank you, William. This post is an example of why you are one of two people Iask for advice on aircraft building.--------Kevin "Axel" PurteeRebuilding NX899KPAustin/San Marcos, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Combustible lines
RE: Pietenpol-List: Combustible lines
Mario,Reject rubber lines! Ultra-lite guys seem to use them a lot, but they areoften far close to the ground than most. You should only use hard aluminum,or steel shrouded flexible lines (from wing to fuselage). Don't beintimidated by manufacturing either of them, as they are easy...plus youalways have your friends on this list to coach you!Gary BootheNX308MB-----Original Message-----
Original Posted By:> mario.giacummo(at)gmail.com
There is another discussion starting suggesting that the fuselage is the right place for the tank. Please read that.Rubber hoses are still in the mainstream of certified aircraft. They are reliable and easy to purchase but be sure you get the right type.Adding the term combustible to your question opens a huge can of worms. It is a question with no correct answer and many=2C many=2C opinions as no one wants to be killed by a post crash inferno . Is it as important to prevent a fire or stop the spread of a fire? If you achieve the first then the second becomes less important. For example many people think firewalls are designed to slow the spread of a fire - I don't believe that is true because it won't work. There are there to prevent a fire from an exhaust leak. So expanding on this concept design a fuel system to try to prevent a fire first.Here is the safest fire system that I can conceive of. I know no one with this so it tells you that compromises are the order of the day. The tank should be in the strongest part of the airplane. That is likely the forward fuselage. The tank should be made of a flexile material such as used in racing fuel cells. There should be a holding cage (tank) and there should be no sharp items near. Note that fuel cell are combustible but in a crash the tank likely won't brake apart. In a fire even aluminum will melt. If stressed aluminum will break.The lines too should be short as possible and flexible. Internal metal bellows lines are large and expensive but are probably the best. Rubber hoses with wire reinforcement=2C internal or external are likely nearly just as good. Many Van's RV owners believe that fuel in the wings are safer that fuel in the fuselage. Unfortunately this is not true and wings are fragile and the fuel is still close enough to be a problem. > Subject: Pietenpol-List: Combustible lines
Original Posted By: brian.kenney(at)live.ca
The firewall cannot 'stop' the spread of a fire. But it may slow the fire in the engine compartment for a long enough time for you to get on the ground before all the good pieces are consumed. Maybe not=2C especially in a wood-and-fabric plane. 'Can't hurt=2C might help' to take your best shot at it=2C though.Good food for thought.Lorenzo
Original Posted By: larharris2 Harris
> To: pietenpol-list(at)matronics.com> m>> > Hello=2C> > Like allways asking for something... I build a wing tank=2C and I want to know if the lines (from the tank to de gascolator) could be of rubber. I ask because i never saw any one of this kind=2C all looks like aluminium. If there is a reason why not to do it with rubber I will be very gratefull if someone can explain me .> > By the way.. this weekend I install the firewall with a ceramic fiber insulation of 10mm.. It was a little bit gross in width=2C but it was the thinner I could find. The firewall is a galvanizad sheet of 0.48 mm. It gave me a lot of work because I put it with the engine in place=2C but after an hour of folding and unfolding it stay in place =3Bo)> > --------> Mario Giacummo> Photos here: http://goo.gl/wh7M4> Little Blog : http://vgmk1.blogspot.com> > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 920#420920> > > > > Attachments: > > http://forums.matronics.com//files/dsc_0181_413.jpg> > > > ============================================> > > ________________________________________________________________________________
Pietenpol-List: Steel-tube fuselage update - landing gear welded
=0A=0A=0AThere is another discussion starting suggesting that the fuselage is the right place for the tank. Please read that.Rubber hoses are still in the mainstream of certified aircraft. They are reliable and easy to purchase but be sure you get the right type.Adding the term combustible to your question opens a huge can of worms. It is a question with no correct answer and many=2C many=2C opinions as no one wants to be killed by a post crash inferno . Is it as important to prevent a fire or stop the spread of a fire? If you achieve the first then the second becomes less important. For example many people think firewalls are designed to slow the spread of a fire - I don't believe that is true because it won't work. There are there to prevent a fire from an exhaust leak. So expanding on this concept design a fuel system to try to prevent a fire first.Here is the safest fire system that I can conceive of. I know no one with this so it tells you that compromises are the order of the day. The tank should be in the strongest part of the airplane. That is likely the forward fuselage. The tank should be made of a flexile material such as used in racing fuel cells. There should be a holding cage (tank) and there should be no sharp items near. Note that fuel cell are combustible but in a crash the tank likely won't brake apart. In a fire even aluminum will melt. If stressed aluminum will break.The lines too should be short as possible and flexible. Internal metal bellows lines are large and expensive but are probably the best. Rubber hoses with wire reinforcement=2C internal or external are likely nearly just as good. Many Van's RV owners believe that fuel in the wings are safer that fuel in the fuselage. Unfortunately this is not true and wings are fragile and the fuel is still close enough to be a problem. =0A=0A=0A=0A============0A============0A============0A============0A=0A ________________________________________________________________________________Subject: Pietenpol-List: Steel-tube fuselage update - landing gear welded
