Pietenpol-List: museum piet
Posted: Sat Sep 06, 2014 5:18 pm
William you were reading my mind! After working out the time zone difference Icalled Mark yesterday as he got my heads off Roy at Oshkosh. Roy is building theshort block and Mark the heads so I am thinking how it would be best to getit all here. I need to talk to you about this. I measured my firewall yesterdayand the the distance you quoted above is 26 5/16 inches from memory. I havewidened the fuselage by approx 2 inches. I have flown a Piet here that was astandard size and although I am 6'1" and about 88kg, the extra couple of inchesmakes all the difference. Things are becoming very real after nearly 5 yearsof building.Scotty--------Tamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comFuslage now on its undercarriage! About to start wing spars...Corvair engine atRoy's Garage waiting to be modified.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: museum piet
