Pietenpol-List: Obligatory Pic
Posted: Sat Sep 06, 2014 10:13 pm
Original Posted By: "john francis"
here is what i think i might know. my heath parasol is covered with stits.. itwas painted through the silver. i primed over the silver with sherwin williamsprimer three coats sanded between coats. primer rolled on then smoothed witha large very fine damp sponge. that left fine marks that were sanded. i thenrolled on three coats of behr exterior latex in cream..sanding between coats.the last coat was sprayed on with a lowes latex paint gun 40 psi thinned flotrolas recommended and 25%. widnshield fluid. i think the best way to judge thefinished product is to look at the paint job then look at your checking accountbalance and accept the fact that you have 2,300 more than you would have ifyou used a certified process. i wouldnt use latex on a 100,000 plane but on a 10,000 it is a very good option forme. thats the jew in me. i wanted the 1927 dope look.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Obligatory Pic
Posted: Sun Sep 07, 2014 2:42 pm
Original Posted By: Doug
The required first sit pic in the Captains chair!--------John FrancisRead this topic online here:
http://forums.matronics.com//files/dscn ... __________
Posted: Sun Sep 07, 2014 2:52 pm
Original Posted By:> Mrkringles(at)msn.com
Did you make airplane noises? :)Doug Dever=0AIn beautiful Stow Ohio> Subject: Pietenpol-List: Obligatory Pic
RE: Pietenpol-List: Obligatory Pic
Posted: Sun Sep 07, 2014 2:57 pm
Original Posted By: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of john francis
Did you make the obligatory airplane sounds?Looks great, John!Jack PhillipsNX899JPSmith Mountain Lake, Virginia-----Original Message-----
Pietenpol-List: Re: Obligatory Pic
Posted: Sun Sep 07, 2014 2:59 pm
Did you make airplane noises? Yes, after everyone left.--------John FrancisRead this topic online here:
Re: Pietenpol-List: Obligatory Pic
Posted: Sun Sep 07, 2014 3:27 pm
Original Posted By: Jack
A friend of a friend called me last night to let me know that there is a partiallybuild Piet down here in SW Florida.I don't know anything about it other than what was told to me. It is supposedlyready to cover and comes with 2 Model B Ford engines. The seller's info is:Lloyd Moore at 239-464-5437.Might be just what someone was looking for.Ted Brousseau90/90 & hope to be at Brodhead next yearRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Obligatory Pic
Posted: Mon Sep 08, 2014 8:13 pm
Subject: Re: Pietenpol-List: Help With AC 8050-88https://
www.faa.gov/aircraft/gen_av/ultralights ... uilt/aw/As noted, "an amateur-built aircraft is eligible for a specialairworthiness certificate in the experimental category for the purpose ofoperating amateur-built aircraft". Experimental is implicit in thedefinition, therefore it is not explicitly stated again in the first twoselections. Of those two selections, the first one applies to you, as youdid not build a kit:"More than 50% of the above-described aircraft was built from miscellaneousparts and I am the owner. (This option is for aircraft eligible foramateur-built certification.)"-RyanOn Mon, Sep 8, 2014 at 12:07 PM, Michael Perez wrote:> I would like to fill out the AFFIDAVIT OF OWNERSHIP FOR AMATEUR-BUILT AND> OTHER NON-TYPE CERTIFICATED AIRCRAFT, However, I am not quite sure which> box I should check. (shown below.) One states amateur built and the other> states experimental, other than amateur built. I guess I mostly question> why the first is not considered experimental.>>________________________________________________________________________________Subject: Pietenpol-List: Re: Obligatory Pic
Posted: Tue Sep 09, 2014 11:02 am
Original Posted By: "namrednos"
For those of you not on Facebook, here is a photo of Santiago's cockpit that I am completely enamored with. This is going tobe one elegant and gorgeous Pietenpol!Mike C.[cid:image001.png(at)01CFCC25.DDC909F0]________________________________________________________________________________Subject: Pietenpol-List: Re: Obligatory Pic
Pietenpol-List: Re: Santiago Morete's panel
Posted: Tue Sep 09, 2014 2:11 pm
Keep up the great work.DO YOU HAVE TO STAY SEATED THERE UNTIL THE GLUE DRIES ON YOUR SEAT PLYWOOD????--------ScottRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Santiago Morete's panel
Posted: Fri Apr 28, 2017 9:39 pm
> To: pietenpol-list(at)matronics.com> > > The required first sit pic in the Captain=99s chair!> > --------> John Francis> > > > > Read this topic online here:> >
http://forums.matronics.com/viewtopic.p ... 157#430157> > > > > Attachments: > >
http://forums.matronics.com//files/dscn0014_127.jpg> > > > ============================================> > > ________________________________________________________________________________
