Did you use the corrected version? (.net instead of .com)Did you replace (at) with the "at" symbol? This forum automatically changes email addresses, replacing the symbol with (at).Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Annual Update
https://www.facebook.com/shelley.tumino ... 7353/Video of engine running on fbg's airframe for the first time last night. Thx toWW for talking me through the ignition timing. Still to go: cowling, paint fuselage and tail. Cover and install wings. Going slower than I want.--------Kevin "Axel" PurteeRebuilding NX899KPAustin/San Marcos, TXRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Annual Update
Shoulda' built a faster plane! Sounds great. I like your pipes...Gary BootheNX308MB-----Original Message-----
Re: Pietenpol-List: Annual Update
Original Posted By: Matt Paxton
Subject: Re: Pietenpol-List: Annual Update
Original Posted By: "Andre B. Charvet"
Pietenpol-List: Re: Annual Update
The standard plans show gusset plates on the inside of struts 1 and 3 on the fuselagesides. The extended fuselage plans do not show those 2 gusset plates. Arethey required on the extended fuselage?--------Harv, 485PBRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Annual Update
Pietenpol-List: Re: Fuselage Gusset Plates
I see the light at the end of the tunnel. Nice shot of adrenalin.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Fuselage Gusset Plates
Original Posted By: "Harvey Plummer"
Harvey, those plate do go on the extended fuse as well. They are shown on my plans, looks like they are 21 1/2" long by 5 3/4" high--------Earl BrownI may not have gone where I intended to go, but I think I have ended up where Iintended to be.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Re: Fuselage Gusset Plates
I should have been more clear. I mean on the bottom inside at struts 1 and 3. Twoindividual gusset plates 2-1/4 by about 2-1/4 and 2-1/4 by about 3.--------Harv, 485PBRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Fuselage Gusset Plates
