Pietenpol-List: Hor. Stab Ends Taper
Posted: Sat Oct 22, 2016 2:47 pm
Original Posted By: "hall698"
I need oscar Zuniga phone number. If you would give it I would be very pleasedThanksCorkySent from my iPad________________________________________________________________________________Subject: Pietenpol-List: Hor. Stab Ends Taper
Posted: Mon Oct 24, 2016 5:57 am
Was wondering what the masses did on this. Should I taper the outboard center beamsstarting from the TE of the Stab to the LE or should I only taper the areaat and forward of the Hor. center beam/LE gussets? It seams as if on the plansthe stab is of the same thickness from the LE to the center beam and then reducesto the LE but I am not sure.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Hor. Stab Ends Taper
Posted: Mon Oct 31, 2016 12:21 pm
Great picture. Thanks so much.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
