Bass wood vs sitka or Doug Fir
Posted: Sun Aug 11, 2019 2:47 pm
by Brian Amato
I've been offered some lovely 2" thick, 16' long bass wood by a friend who has been storing them for years. I'm wondering about planing and ripping them for the longerons. I have the rest of the wood (Sitka) for uprights and cross members but I'm wondering if anyone has any thoughts about bass wood?
Some of the things I've found on the web says it compares favorably.
Anybody
Re: Bass wood vs sitka or Doug Fir
Posted: Sun Aug 11, 2019 11:14 pm
by taildrags
Brian; just looking at the Forest Products Laboratory tables that list the mechanical properties of various woods, American basswood is considerably weaker than both Sitka spruce and Douglas fir in most of the important characteristics. It is lighter than either of the other two woods, but proportionately weaker in modulus of rupture, ultimate strength in tension, and various other structurally-significant parameters. The Air Camper airframe is said to be hell-for-stout, but it's up to you to judge just how near to hell you care to build your airframe to test the validity of that saying ;o)
-Oscar Zuniga
Posted: Mon Aug 12, 2019 6:36 am
by Brian Amato
Fair enough. No basswood
Posted: Wed Aug 14, 2019 4:59 am
by VincentDunn
Brian,
Since Basswood is both lighter and less strong you could, in theory, increase the longeron dimensions to, say, 1.25 inches square and achieve the same weight and strength os spruce. Oscar might suggest the correct dimensions to achieve spruce parity. Also, look at Western Hemlock as an alternative. I built my whole plane from W Hemlock and found it to be excellent quality and locally available here in the Pacific NW. Good luck!
Posted: Wed Aug 14, 2019 6:23 am
by Brian Amato
Thanks everybody. More a case of lazy and frugal on my part than anything else. A good friend had this basswood and offered it to me.
I built the Corben Jr. Ace using nice, straight grain, Doug Fir and it was terrific. Even the FAA inspector said it was superior to much of what he sees.
We have a small but well stocked lumber yard up here in N. Michigan that stocks (for some reason I still don't understand) some lovely tight grained DF. I called a couple days ago and the guys said he has some pretty impressive looking stuff right now. I'm going out today to paw thru the stuff and see. Hope to come home with some 14' stuff for longerons.
Stay tuned...
Posted: Wed Aug 14, 2019 10:40 am
by taildrags
My recommendation on changing the fuselage framing member sizes is "don't do it". You'll end up scratching your head more often than getting anything done, because changing the dimensions will lead to changes in many, many other connections throughout the airplane and you'll probably be thinking, sketching, figuring, and adjusting your way through the entire build.
Posted: Wed Aug 14, 2019 11:29 am
by Brian Amato
I agree with Oscar. Best to follow the plans. Guys that think they have a better idea and start changing things wind up chasing their tail through the whole build. Just not worth it.
Posted: Fri Aug 16, 2019 4:01 pm
by Terry Hand
"The Air Camper airframe is said to be hell-for-stout, but it's up to you to judge just how near to hell you care to build your airframe to test the validity of that saying ;o)"
Well put, Oscar (as you typically do so well).
Have you considered where you might be able to use the Basswood in a non-structural location? Building the framework for the cowl supports as shown on Drawing number 1, for example? The mid supports for the turtledeck? I would not say that there is NO location for using the Basswood, just not as part of the structural framework.
Posted: Mon Aug 19, 2019 9:25 am
by Brian Amato
Bass wood in other areas: Good idea ......I might be able to use it in other areas. It's lovely stuff !!
