fuselage length
Posted: Sat Apr 25, 2020 8:31 pm
by Tbopper
When I bought our Pietenpol project, I was told the fuselage was a long one. I was not aware that a shorter version of the fuselage was available. What is the difference in the length. I am flying at the rear of the Center of gravity and I am wondering if the shorter fuselage would help. Is there a set of plans available for the shorter version?
Re: fuselage length
Posted: Sat Apr 25, 2020 8:54 pm
by PoconoJohn
My original plans are for the shorter fuselage with a page added to show changes for the longer fuselage. Difference is 10" if my memory is correct (about 173" and 163"). You can purchase plans here:
https://www.pietenpolaircraftcompany.co ... nstruction
Re: fuselage length
Posted: Sun Apr 26, 2020 9:05 am
by Earl Brown
Tbopper;
The shorter fuselage might be a bit lighter, but it won't solve the rear CG issue.
Both the long and short fuselage are prone to CG issues. While it's a bit of a project to fix after the plane is finished, it can be done.
You mentioned that you bought the project, was it flying when you bought it?
Are you and the original builder about the same weight?
What engine is in the plane? Are the cabane struts vertical or slanted back any?
Re: fuselage length
Posted: Mon Apr 27, 2020 1:32 am
by Tbopper
The plane was not finished. It was picked up in pieces. After assembly, a weight and balance was done and that is when I found the CG was out. The wing was moved back 4 inches. That helped a little bit. The engine is a continental 65. It had a wooden Edward Sterba
propeller that I changed for a 19 lb. metal prop. I 'm now 3 inches past the rear CG. I weigh 225 and stand 6' 2". My desire is to loose weight BUT that is not going well. If the difference in the length of the fuselages is 10 inches I don't think I would attempt to shorten it. Other that hanging dead weight on the nose; which I don't want to do, I'm pretty much out of ideas. It will fly hands off. If both the long and short fuselage are prone to CG issues, what as been done to correct the problem or do I just suck it up and fly it, which by the way is a blast.
Re: fuselage length
Posted: Mon Apr 27, 2020 10:16 am
by Earl Brown
So you are at 23" aft CG?
What are the min. and max. pilot weights shown on the W&B?
The wing is back 4"- does your W&B show how far back the wing LE is from the firewall?
Re: fuselage length
Posted: Mon May 04, 2020 8:46 pm
by at7000ft
Tbopper wrote: Mon Apr 27, 2020 1:32 am
The best solution is to make a new longer engine mount, moves cg forward and adds minimal weight.
Re: fuselage length
Posted: Fri May 08, 2020 11:44 pm
by Terry Hand
I would submit to you that your best option is to contact William Wynne or Ryan Mueller, let them look at your numbers and let them propose your best solution. They know the Pietenpol W&B as well as anyone.
Re: fuselage length
Posted: Sat May 09, 2020 6:58 pm
by tom kreiner
Take a close look at your tailwheel, as it adds the largest moment of any component due to arm length. Reducing weight at the tail is the best bet for changing cg. Below are a few suggestions.
I had a 7 lb. Matco tailwheel given to me, and rather than using it, I am fabbing the twin tubing open frame per plans along with a lightly modified RV-6 tailwheel mechanism. One change drops weight by over 3 lbs. Don’t use the triple springs for your tailwheel; they’re solid steel!
Dropping 3.5 lbs at that arm will put my plane close to forward cg.
Also, if you have 1/8 tailplane wires, consider using 1/16 in wires. Plenty of Piets have HUGE t’buckles, fittings, and wire at the tail that really affects cg.
Drill 1” holes in the turtle deck stringers, several Piets have done this and while in the uncovered state they look like Swiss cheese, you’ll drop another lb. or so.
