Tall pilots and leg room
Posted: Thu Oct 29, 2020 4:56 pm
by EzraDunlop
Hi everyone, I’ve been looking at buying a Pietenpol and was wondering about the cockpit size. I’m 6’4” and interested to hear the thoughts of any similarly sized pilots. Is there enough room that your knees don’t hit the panel? Are there ways of modifying an already built piets to give more leg room? I know the best option would be to just find one and sit in it but there aren’t any nearby that I know of. I could just fit into a Flybaby with my knees almost touching the bottom of the panel for reference. Thanks in advance for the help!
Re: Tall pilots and leg room
Posted: Thu Oct 29, 2020 5:31 pm
by Earl Brown
Where are you located?
Posted: Fri Oct 30, 2020 4:23 pm
by EzraDunlop
Southern alberta
Posted: Wed Nov 04, 2020 9:01 am
by Spark6
Ezra, at 6' 1", I'm not quite as tall as you are, but I don't have any trouble with legroom on my Piet. I'm even able to fly in hiking boots, though it takes a little longer to thread myself into the cockpit properly. I DO find that, sitting straight up, I'm a bit above the windscreen protection in cruise, but that can be remedied with a windscreen change and hasn't bothered me yet.
Posted: Wed Nov 04, 2020 10:25 am
by taildrags
I'm only 5'-9" so I don't have a valid opinion on this, but I would venture to say that there could be several inches' difference between two pilots who are both 6'-4". One could be long in the torso, the other could have long legs. The pilot with the longer torso would probably be looking out over the top of the windscreen but with legs that fit fine, while the other might sit lower in the cockpit but have to fly with knees bent. It's best to just find a Piet and sit in it to see how you fit.
Posted: Thu Nov 05, 2020 11:07 pm
by EzraDunlop
If I wasn’t able to sit down and get my knees below the panel would it be difficult to move the rudder pedals forward in the fuselage a few inches?
Posted: Sat Nov 07, 2020 4:40 pm
by taildrags
You would most likely have to either eliminate the front seat or develop a different front seat design, because if you move the rudder bar forward very much, it'll be touching the front seat support at full deflection.
Posted: Mon Nov 09, 2020 8:47 am
by Spark6
I think, like Oscar says, if you have a rudder bar, you're likely stuck. If you have pedals, you might be able to re-mount them. It's a fairly straightforward system on mine, but moving the pedals forward on my particular aircraft WOULD render my brakes unusable. YMMV.
