fuselage cross members and tailpiece
Posted: Fri Jan 29, 2021 12:12 pm
I have finished the sides of the fuselage and now having issues with where to put all the cross members. Looking at Diagram #1 and #4 there are measurements but not for the "long" fuselage. I do notice markings for the wheel crossmembers and the dual control diagram shows where they will be in relation to the vertical spars but all of the others (particularly those aft of the pilot seat) would be at different distances than mentioned. I've found three links on crossmember questions but they don't seem to really answer my question beyond the position of the wheel braces.
Secondly, looking at tapering the tail down to a half inch on both sides for an inch width (at the tail end) epoxied together leaves considerable room for potential slop in the tailpost. I was thinking of possibly cutting out my tailpiece spar and epoxy a new one on after tapering the longerons and spar #14 on each side. If I start with a tailpiece 1"X1-1/4" I can taper it to meet the longerons and be 1" at the end. I'm thinking this way the tailpiece will be solid and I'll have a more solid construct holding the third rudder hinge.
Any feedback appreciated.
