Quick question on the 8 tail brace fittings
Posted: Tue Feb 23, 2021 1:29 pm
by PoconoJohn
I made the tail brace fittings to match the drawing. Will they work?
Re: Quick question on the 8 tail brace fittings
Posted: Tue Feb 23, 2021 10:32 pm
by taildrags
PJ, I'm not sure what the question is. If you're referring to the very simple bent metal tabs that the brace wires attach to, there's not much to them. As with all of these details, you can get a lot of verification of your questions or doubts by looking at what others have done, most notably by visiting the fabulous "library" of pictures on Westcoastpiet.com . For example on the tail brace fittings, here's a link to a picture of the upper one on Bill Rewey's Piet-
http://westcoastpiet.com/images/Bill%20 ... CF0045.JPG . Or Mike Cuy's-
http://westcoastpiet.com/images/Mike_Cu ... 20side.jpg . Lots and lots of excellent photos on Chris Tracy's super website.
Posted: Wed Feb 24, 2021 2:32 pm
by PoconoJohn
I learned awhile ago to not go by the measurements or drawings, but I had already made the fittings. I'm about to drill holes in the beams to match up with the holes in the fittings. I don't know if any builder discovered the fittings should have been built bigger or if there's another problem...maybe when connecting the brace wires. I made the holes 3/16". I often look at photos, but I can't tell what the dimensions are.
Posted: Wed Feb 24, 2021 3:47 pm
by taildrags
You're correct that there are a number of places on the Air Camper which if you build as per dimensions on the plans, may 'trap' either the bolt head or the nut (or both) when you install the part or install another fastener that faces that one. I have a couple of places on my airplane where I wish the fittings would have been lengthened just a bit to provide more clearance to insert the bolt, or the washer, or something else.
Posted: Fri Feb 26, 2021 7:57 am
by Earl Brown
John, yes most of the fittings would benefit from being slightly longer than the plans show.
I made mine to the plans and it would make things a little easier if they were longer, but they will work fine so I'm not going to stop the progress I've been making this week and go back and remake them right now!
Posted: Fri Feb 26, 2021 2:44 pm
by PoconoJohn
Thanks! You must be getting near the finish line.
Posted: Fri Feb 26, 2021 5:41 pm
by Dana H
John, when you go to hook up your cables to the fittings and find they are slightly too close just loosen the nuts on the fitting a couple threads book them up and re-snug. Might be just enough to get it done.
Posted: Fri Feb 26, 2021 5:43 pm
by Dana H
Dana H wrote: Fri Feb 26, 2021 5:41 pm
John, when you go to hook up your cables to the fittings and find they are slightly too close just loosen the nuts on the fitting a couple threads hook them up and re-snug. Might be just enough to get it done.
Posted: Sat Feb 27, 2021 6:23 pm
by Earl Brown
PoconoJohn wrote: Fri Feb 26, 2021 2:44 pm
Well, close to the finish line for this task!
Lots more to go. I really try to just focus on the task at hand, looking at the whole thing can get overwhelming!
Posted: Mon Mar 01, 2021 2:58 pm
by PoconoJohn
Thanks Dana!
Posted: Mon Mar 01, 2021 2:59 pm
by PoconoJohn
Earl Brown wrote: Sat Feb 27, 2021 6:23 pm
Yes!
