Vertical/Horizontal Stabilizer Brackets
Posted: Thu Mar 18, 2021 5:15 pm
At the front of the horizontal stabilizer, the plans call for two screws to connect it to the fuselage. Then there are the brackets at the base of the vertical stabilizer. I see in photos builders are using bolts. I saw one where it appears screws were used (vertically) at the rear in the area where there are four brackets (but bolts horizontally connecting the opposite side bracket).
I'm going to assume bolts is the way to go. AN3 bolts will work in the holes I made, I just have to figure out the length.
Does anyone have any advice or suggestions? Would you do something differently? After this, I start gluing the horizontal stabilizer. I already drilled the holes for the brace wire fittings.
While I'm here....the horizontal stabilizer leading edge is rounded with a lip. Did anyone flatten (sand) the part that contacts the fuselage?
I'll use a corvair engine. I plan to swing the the vertical stabilizer leading edge 1/2" to aircraft right (rear will be on center)
Thank you!
Thank you!
