Vertical stabilizer doesn't touch front of HS
Posted: Fri Mar 19, 2021 8:12 pm
by PoconoJohn
Hello again....just to see how it's shaping up, I set the vertical stabilizer on the horizontal stabilizer. The front is just about 3/16" in the air. There are 3/16" pieces at the three locations where the VS bottom meets the HS. Is something wrong?
Re: Vertical stabilizer doesn't touch front of HS
Posted: Sat Mar 20, 2021 9:47 am
by Earl Brown
Just add a spacer under the fin
Posted: Sat Mar 20, 2021 1:12 pm
by doug bryant
this is my seventh piet and i just leave the space as it is much easier to cover. but, shiming can be done.
Posted: Sat Mar 20, 2021 1:16 pm
by doug bryant
Posted: Sun Mar 21, 2021 4:00 pm
by PoconoJohn
doug bryant wrote: Sat Mar 20, 2021 1:12 pm
Is it covered before attaching to the HS...or is it all put together and then covered?
Posted: Sun Mar 21, 2021 6:03 pm
by doug bryant
assemble entire aircraft, check it about three times, then disassemble and cover.
