Pietenpol Air Camper Project for Sale, lowered price
Restorer
Post by Restorer »
Pietenpol Project for Sale
Left wing, complete with aileron hinge fitting, brackets for aileron control cable pully, wing strut attach
fitting, all tie rods, wing attach fittings to center section (small 1 ¼” damage plywood upper leading
edge, 3” roughness on edge on bottom of front spar).
Right wing, complete with tie rods, wing attach fittings to center section, wing strut attach fittings
needs aileron hinge attach fitting and brackets for aileron control cable pully.
Left aileron complete, with aileron cable control fitting
Right aileron, complete, needs metal trailing edge and aileron control cable control fitting
One vertical fin - wood
Two elevators - wood
One rudder – wood, with attach fittings to vertical fin
Two fuselage sides - metal
One vertical fin – metal
One elevator - metal
Two wire wheels with 3.50 x 18 tires, wheels have chrome rims
Two complete wheel brake assemblies, pads appear nearly new.
All wood components have been varnished
To finish the fuselage, you would have to weld only 6 cross tubes and one diagonal to finish the top and 6 cross tubes and 6 diagonals to finish the bottom of the fuselage.
$ 995.00
Call or contact Mike Walton for pictures and further information 480-861-4658 mjskwalton@aol.com
JRosene
Re: Pietenpol Air Camper Project for Sale, lowered price
Post by JRosene »
Where is this project located?
