Plywood delamination?
Posted: Thu Feb 08, 2024 7:28 am
Hello all:
My question this time has to do with plywood, specifically 1/8” 4’ x 8’ mahogany I received from ACS. This plywood came with the “fuselage kit.” Very pricey nowadays so I expect good stuff. Ordered in OCT received in Jan and both pieces pulled apart easily with fingernails. I sent it back. They sent two new pieces and though they seemed a little better I could still pull whole sections of ply apart with not too much effort. The plies come apart at the glue joint. I assume the glue should be stronger and if the plies come apart at all it should be the wood tearing and not the glue. Am I being too picky with my delamination testing of the mahogany plywood? Is this normal?
Thanks…
Thanks…
