Oddly Sized Piet Fuse
Posted: Mon Nov 11, 2024 4:04 pm
Hi All,
Been a longtime reader of this forum and am constantly inspired and motivated by the incredible builders/flyers here.
I'm beginning a Piet project that I acquired a few years ago. However, it has some fuselage dimensions that don't appear in any plans I have so I thought I would ask the group as to their thoughts.
First, the overall length of this Piet is 169". It looks like it was built primarily to the short fuse plans but gains length through a specific increase in dimension. From the firewall back to the first vertical support, the plans call for either 16 1/2" in the supplementary plans or I believe 12 1/2" in the short plans. This project however was built with that vertical support at 20 1/2" back from the firewall. So my first question is are there any support implications for the engine weight etc by having this support further back by an extra 4". Does it need any beefing up?
The second is that since they used the short plans for most of it, the pilots sit further back relative to the firewall for an airplane that is about 3 1/2" shorter than the long plans. This will move my CG rearwards. I have done some calculations using a weight of around 675 lbs with 25 lbs at the tailwheel. I think I can get this into a max rearward CG of 20" (at extreme case, 2 x weighty pilots, little gas) if I slant the wing about 4" after of vertical. The leading edge of the wing would likely be back about 13 1/2" from the firewall prior to slanting
Wondering who else has slanted that much and what our builders thoughts are on these two issues.
Thanks very much!
Chris
Thanks very much!
Chris
