Pitot tube
Posted: Sat Jan 04, 2025 12:52 pm
by jperkins
Looking for ideas and recommendations on Pitot system. What systems have you used and how are they mounted?
Re: Pitot tube
Posted: Sat Jan 04, 2025 2:55 pm
by robin8er
Assuming you plan to only fly day VFR, you don’t need much. 1/4 inch aluminum or stainless tubing is all you need. Connect that to some flexible 1/4 tubing and run that to the airspeed. That’s about all there is to it.
Re: Pitot tube
Posted: Thu Jan 09, 2025 9:30 pm
by geresh
I overthought this alot on my build, but it seems to have worked out well. I drilled a 3/8 hole in the leading edge, and epoxied in a 3/8 aluminum tube that is bent to go over the spar. I then threaded a piece of 1/4" brass tubing to thread in both ends. The aluminum tube is cut off flush with the leading edge, which makes covering a breeze. The plastic tubing that runs to the cockpit is fastened behind the front spar, which makes access through one of the inspection holes possible. And I figure if the pitot tube ever gets bent, I simply unscrew it and screw a new one in. Oh, and I used one of those wind operated flappers to keep the bugs out when it's parked in the hangar. Somehow I don't have pictures of it, but maybe my sketch will help.
Re: Pitot tube
Posted: Thu Jan 09, 2025 9:31 pm
by geresh
Re: Pitot tube
Posted: Sun Jan 12, 2025 2:09 pm
by danoliver
I did mine similarly. But, I poked it out at about the jury strut location. That is too close inboard though I think. Whenever I do my run up I register 20 knots on my airspeed indicator.
Re: Pitot tube
Posted: Sun Jan 12, 2025 6:33 pm
by Clay Hammond
Does an airspeed system HAVE to be pitot based to be accepted for airworthiness? I'm not being rhetorical, honest question. Why put all the weight and plumbing in of a pitot tube back to a gauge when you could have a Johnson type out on the strut that can be just as effective?
Re: Pitot tube
Posted: Sun Jan 12, 2025 11:04 pm
by taildrags
14 CFR 91.205 covers day VFR flight for U.S. aircraft with standard category airworthiness certification and all it says is that an airspeed indicator is required, period. So if it's good enough for standard category, it should certainly be good enough for experimentals. I suppose you could use a knotted line trailed overboard and count the knots that run through your fingers in a given increment of time. Calibrated knots, of course.
Re: Pitot tube
Posted: Mon Feb 03, 2025 10:17 pm
by jperkins
Thank you everybody for the responses and the great ideas. I have been over thinking this a little bit.
Re: Pitot tube
Posted: Thu Feb 06, 2025 5:02 pm
by Douwe
Yes, a Johnson-type ASI or a hall-type is perfectly acceptable for experimental category. I've flown with a johnson on Re-PIET since 2012.
