Original Posted By: "BritishJim"
Hi Jeff,I bought the home built Grove 6.00x6 magnesium wheel and disc brake kit from aircraftspruce and bought the tires and tubes direct from Desser Tire. I thinkaired up they were inch taller than on the plans 20" vs 19" if I remember correctly.I am working on building my landing gear so not sure on the stance whenon yet but in my opinion they are just right for the look I want. Not too bigand not too small. All my measurements are to the plans with steel gear and ModelA engine.RobRead this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/imag ... ___Subject: Pietenpol-List: Any Piets living in Southern Ontario?
Re: Pietenpol-List: Any Piets living in Southern Ontario?
Greetings all!I'm in London, Ontario for the next couple of weeks and wondering if anyone knowsof any Piets in the area, or has contact information for owners?My full-time base is Nova Scotia where there is virtually no intelligent life,let alone a Piet owner. I figured, now that I'm in the civilized world for a fewweeks, it might be good to try and hunt one down.Any help would be greatly appreciated. Jim.--------Your nose is high; you're in the sky. The other way around; you'll hit the ground....Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Any Piets living in Southern Ontario?
RE: Pietenpol-List: Any Piets living in Southern Ontario?
There are a couple in the Midland area but that is a longer driveRobert Gow,President and DAO Manager.Avionics Design Services Ltd.Phn 705-527-6095Cell 416-434-3393Fax 705-527-6028www.avionicsdesign.ca -----Original Message-----
Re: Pietenpol-List: Re: Any Piets living in Southern Ontario?
Robert & Scott....thank you for such prompt replies!Scott - are you @hotmail.com or @hotmail.ca? It is cut off on your username andI don't want to email some random Joe who will think I'm obsessed with an actualman called "Pete".Thanks,Jim.--------Your nose is high; you're in the sky. The other way around; you'll hit the ground....Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Re: Any Piets living in Southern Ontario?
