Original Posted By: "cdlwingnut"
Thanks. I will be sending a check soon, printed out the application form.Thanks,RaySent from my iPad> On Mar 6, 2017, at 6:00 AM, pweeden wrote:> > > Hi Ray,> > I'm not seeing you on the membership list at all. If you can join up again, I'llsend the most recent newsletter.> > Pat> > > Ray Krause wrote:>> Pat,>> >> Would you please check out my subscription for me. I tried to check with >> John, but got no response. Since I have not received any newsletters for quitesome time, I assume I'm not paid up. I would love to pay up and even purchasethe last year's worth of letters.>> >> Thanks,>> Ray Krause>> 843 Jay Street>> Colusa, CA95932>> > > > > > > Read this topic online here:> > http://forums.matronics.com/viewtopic.p ... 918#466918> > > > > > > > > ________________________________________________________________________________Subject: Pietenpol-List: Glue Joint?
Pietenpol-List: Re: Glue Joint?
Original Posted By: "Rick Schreiber"
It looks like some of the t-88 ran out of a couple of my joints before it curedhow do you know if you have a good joint?and Can you add more t-88 into a joint you aren't 100% sure ofThanksRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Glue Joint?
How much pressure did you apply to the joint? Are you talking about T-88 oozingout under a plywood gusset? If you applied an adequate layer of T-88 to bothsurfaces and did not apply a heavy clamping pressure you are probably OK. I hadT-88 ooze out of all of my joints. I just wiped and/or scraped away the excess.If you don't have some oozing, how would you know you applied enough adhesive?Rick SchreiberNX478RSValparaiso, INRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Glue Joint?
